@ Dat - I have send you 2 VS2010 solutions to test. For others interested… see below:
Win32 console code, used to send data to cobra
using System.Net;
using System.Net.Sockets;
using System.Text;
// references needed
// System
// System.Core
// 2014 March 01 : Win32 console utility of HTTP post code to demonstrate a number of issues on CobraII
// Make sure IP address on device is same as used below her (192.168.0.130)
namespace WinSockSend
internal class Program
private static void Main()
Console.WriteLine("Socket send test utility. Press any key to stop.");
using (var clientSocket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp))
clientSocket.SendBufferSize = 1460;
var r = new Random();
try
clientSocket.Connect("192.168.0.130", 80);
SendDummyHTTPHeader(clientSocket);
var ioBuffer = new byte[1460];
var b = (byte) r.Next(255);
for (int i = 0; i < 1460; i++)
ioBuffer[i] = b;
SocketWrite(clientSocket, ioBuffer, ioBuffer.Length);
if (Console.KeyAvailable)
while (Console.KeyAvailable)
Console.ReadKey();
clientSocket.Close();
return;
catch (Exception exception)
Console.WriteLine(exception.Message);
private static void SendDummyHTTPHeader(Socket clientSocket)
// obtain ip address of the computer we run this test code
// ip is 'neccesary' to put in the http request header
string thisTestMachineIP = "";
IPAddress[] ipaddressen = Dns.GetHostAddresses(Dns.GetHostName());
foreach (IPAddress ip in ipaddressen)
if (ip.AddressFamily == AddressFamily.InterNetwork)
thisTestMachineIP = ip.ToString();
break;
// Create an HTTP request header
var sb = new StringBuilder();
// sb.Append("POST http://192.168.0.130:8000/upload.cgi HTTP/1.1\n"); // when using http port 8000 instead of 80
sb.Append("POST /upload.cgi HTTP/1.1\n"); // when using default http port 80
sb.Append("Host: 192.168.0.130\n");
sb.Append("Content-Length: 1000000\n");
sb.Append("Origin: http://" + thisTestMachineIP + "\n");
sb.Append("User-Agent: Schedulon Music File Upload Utility V1.0\n");
sb.Append("Content-Type: multipart/form-data; boundary=----WebKitFormBoundary1Z4ZlNEzO4kVBBwY\n");
sb.Append("Referer: http://" + thisTestMachineIP + "\n");
sb.Append("\n");
sb.Append("------WebKitFormBoundary1Z4ZlNEzO4kVBBwY\n");
sb.Append("Content-Disposition: form-data; name=\"datafile\"; filename=\"testfile.mp3\n");
sb.Append("Content-Type: application/x-msdownload\r\n\r\n");
byte[] buffer = Encoding.UTF8.GetBytes(sb.ToString());
SocketWrite(clientSocket, buffer, buffer.Length);
private static void SocketWrite(Socket socket, byte[] ioBuffer, int length)
int written = 0;
do
written += socket.Send(ioBuffer, written, length - written, SocketFlags.None);
return;
} while (written < length);
Code running on Cobra II with external ENC28 and SD card
using System.IO;
using System.Net;
using GHI.Hardware.G120;
using GHI.Premium.IO;
using GHI.Premium.Net;
// References needed
// GHI.Hardware.G120
// GHI.Premium.IO
// GHI.Premium.Net
// GHI.Premium.System
// Microsoft.SPOT.Hardware
// Microsoft.SPOT.Native
// Microsoft.SPOT.Net
// mscorlib
// System
// System.Http
// System.IO
// 2014 March 01 : HTTP server demo code to demonstrate a number of issues
// Hardware: COBRA II with external ENC28 v1.1 ethernet module and Sandisk Extreme pro 8GB sd card
// Fimrmware 4.2.11.2
// Dev. Environment: Win7/32 VS2010
namespace CobraIISockReceive
private static EthernetENC28J60 _nic;
private static HttpListener _listener;
private static PersistentStorage _storage;
// Setup Storage
try
_storage = new PersistentStorage("SD");
_storage.MountFileSystem();
catch
Debug.Print("No SD Card");
// Setup network
_nic = new EthernetENC28J60(SPI.SPI_module.SPI1, Pin.P1_5, Pin.P0_1, Pin.P0_10);
if (!_nic.IsOpen)
_nic.Open();
NetworkInterfaceExtension.AssignNetworkingStackTo(_nic);
_nic.NetworkInterface.EnableStaticDns(new[] {"8.8.8.8", "8.8.4.4"});
_nic.NetworkInterface.EnableStaticIP("192.168.0.130", "192.168.0.1", "255.255.255.0");
while (Equals(IPAddress.GetDefaultLocalAddress(), IPAddress.Any))
Debug.Print("IP address is not set yet.");
Thread.Sleep(25);
// create a target file directory if not exist
if (!Directory.Exists(@ "\SD\Media"))
Directory.CreateDirectory(@ "\SD\Media");
RunHTTPServer();
private static void RunHTTPServer()
_listener = new HttpListener("http", 80) {MaximumResponseHeadersLength = 10};
_listener.Start();
try
HttpListenerContext ctx = _listener.GetContext();
if (ctx != null)
object clientInputStream =
typeof (HttpListenerContext).GetField("m_clientInputStream", BindingFlags.NonPublic | BindingFlags.GetProperty | BindingFlags.Instance).GetValue(ctx);
Type cist = clientInputStream.GetType();
var t = (Socket) cist.GetField("m_Socket", BindingFlags.NonPublic | BindingFlags.GetProperty | BindingFlags.Instance).GetValue(clientInputStream);
t.SetSocketOption(SocketOptionLevel.Socket, SocketOptionName.DontLinger, true);
t.SetSocketOption(SocketOptionLevel.Tcp, SocketOptionName.NoDelay, true);
t.SetSocketOption(SocketOptionLevel.Tcp, SocketOptionName.ReuseAddress, true);
HandleRequest(ctx);
Debug.Print("HttpListenerContext = NULL");
catch (SocketException socketException)
Debug.Print("Socket Error: " + socketException.ErrorCode);
switch (socketException.ErrorCode)
case 10050: // network down (happens when cable removed) **
case 10051: // network unreachable
_listener.Close();
return;
case 10052: // network dropped connection on reset
case 10053: // software caused connection abord
case 10054: // connection reset by peer ( happens when browser shutsdown or refresh) **
break;
catch (Exception)
_listener.Close();
return;
private static void HandleRequest(HttpListenerContext ctx)
var r = new Random(); // used for random filename generator
FileStream outPutFileStream = null; // used to write data to SD card
try
// Create a file with random name
// @ GHI : Sometime CLR_IO_ERROR(1) ????
outPutFileStream = new FileStream(@ "SD\Media\datadump" + r.Next() + ".bin", FileMode.Create);
Debug.Print(outPutFileStream.Name);
// @ GHI : using a http port other as 80 for example 8000 genereates an System.Net.ProtocolViolationException : See comments at the end of this file
// this actually not the problem i wanted to demonstrate here, but came accros this
HttpListenerRequest request = ctx.Request;
const int bufferLength = 1460; // our test length
var inputData = new byte[bufferLength]; // buffer for received data
long totRead = 0; // total read counter, just for debugging
// loop receiving bytes and write them to file
int read = request.InputStream.Read(inputData, 0, bufferLength);
if (read == 0)
Debug.Print("Connection gone...Length 0");
break;
// @ GHI : Somtimes after receiving 32767 bytes the write generates an exception (See below)
outPutFileStream.Write(inputData, 0, bufferLength);
totRead += read;
Debug.Print(totRead.ToString());
catch (Exception ex)
Debug.Print(ex.Message);
finally
ctx.Response.Close();
if (outPutFileStream != null)
outPutFileStream.Close();
outPutFileStream.Dispose();
26435
27895
29355
30815
#### Exception System.IO.IOException - CLR_E_FILE_IO (1) ####
#### Message:
#### Microsoft.SPOT.IO.NativeFileStream::Write [IP: 0000] ####
#### System.IO.FileStream::Write [IP: 002a] ####
#### CobraIISockReceive.Program::HandleRequest [IP: 006d] ####
#### CobraIISockReceive.Program::Run [IP: 0035] ####
#### CobraIISockReceive.Program::Main [IP: 00a2] ####
A first chance exception of type 'System.IO.IOException' occurred in Microsoft.SPOT.IO.dll
Exception was thrown: System.IO.IOException
#### Exception System.Net.ProtocolViolationException - 0x00000000 (1) ####
#### Message: Unsupported HTTP version: HTTP/1.
#### System.Net.HttpListenerRequest::ParseHTTPRequest [IP: 0084] ####
#### System.Net.HttpListenerContext::get_Request [IP: 000d] ####
#### CobraIISockReceive.Program::RunHTTPServer [IP: 0038] ####
#### CobraIISockReceive.Program::Main [IP: 00b1] ####
