Hi
Sorry for returning so late… This is my first attempt on an FTP client for the FEZ Panda capable of uploading/appending a file to a FTP server. Testet against a Netgear NAS with no problems encountered.
(PS I can’t take credit for all the code…the implemetation is a mix of forum-code and selfmade code )
Usage:
FtpClient.initializeNetwork();
FtpClient.connectToRemoteFtpServer("--IPADRESS--", 21, "ftp_user", "Password");
FtpClient.changeWorkingdirectory("Ftp_root");
FtpClient.appendToFile("Test.txt", Encoding.UTF8.GetBytes("filecontent as string"));
FtpClient.disconnectFromRemoteFtpServer();
Class impelmentation
using GHIElectronics.NETMF.Net.Sockets;
using GHIElectronics.NETMF.Net.NetworkInformation;
using System.Text;
namespace FEZ_Panda_II_FTP_Client
static class FtpClient
static Socket clientSocket;
public static void initializeNetwork()
// Enable the Ethernet
WIZnet_W5100.Enable(SPI.SPI_module.SPI1, (Cpu.Pin)FEZ_Pin.Digital.Di10, (Cpu.Pin)FEZ_Pin.Digital.Di7, true);
Dhcp.EnableDhcp(new byte[] { 0x00, 0x26, 0x1C, 0x7B, 0x29, 0xE8 }, "FEZ Temp/Light");
Debug.Print("Network settings:");
Debug.Print("IP Address: " + new IPAddress(NetworkInterface.IPAddress).ToString());
Debug.Print("Subnet Mask: " + new IPAddress(NetworkInterface.SubnetMask).ToString());
Debug.Print("Default Getway: " + new IPAddress(NetworkInterface.GatewayAddress).ToString());
Debug.Print("DNS Server: " + new IPAddress(NetworkInterface.DnsServer).ToString());
public static void connectToRemoteFtpServer(string remoteHost, int remotePort, string remoteUser, string remotePass)
IPAddress serverFTP_IP = IPAddress.Parse(remoteHost);
IPEndPoint serverEndPoint = new IPEndPoint(serverFTP_IP, remotePort);
clientSocket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
clientSocket.Connect(serverEndPoint);
Debug.Print("Connected to remote server");
getRemoteServerReply(220);
sendCommand("USER " + remoteUser);
getRemoteServerReply(331);
sendCommand("PASS " + remotePass);
getRemoteServerReply(230);
public static void changeWorkingdirectory(string directory)
sendCommand("CWD " + directory);
getRemoteServerReply(250);
public static void uploadFile(string fileName, byte[] fileData)
sendCommand("TYPE I");
getRemoteServerReply(200);
sendCommand("PASV");
IPEndPoint uploadEndpoint = getUploadEndpoint(getRemoteServerReply(227));
clientSocket.SendTimeout = 30000;
clientSocket.ReceiveTimeout = 30000;
sendCommand("STOR " + fileName);
Socket uploadSocket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
uploadSocket.Connect(uploadEndpoint);
getRemoteServerReply(150);
int count = 0;
while (count < fileData.Length)
count += uploadSocket.Send(fileData, count, fileData.Length - count, SocketFlags.None);
Debug.Print("Uploaded bytes: " + count.ToString());
uploadSocket.Close();
getRemoteServerReply(226);
public static void appendToFile(string fileName, byte[] fileData)
sendCommand("APPE " + fileName);
int count = 0;
public static void disconnectFromRemoteFtpServer()
sendCommand("QUIT");
getRemoteServerReply();
clientSocket.Close();
public static void sendCommand(string command)
Debug.Print("Client request: " + command);
Byte[] cmdBytes = Encoding.UTF8.GetBytes((command + "\r\n"));
clientSocket.Send(cmdBytes, cmdBytes.Length, 0);
public static IPEndPoint getUploadEndpoint(ServerReply serverReply)
string ipAndPort = "";
int firstPar = 0;
int lastPar = 0;
firstPar = serverReply.servereply.IndexOf("(");
lastPar = serverReply.servereply.IndexOf(")");
ipAndPort = serverReply.servereply.Substring(firstPar + 1, lastPar - firstPar - 1);
string[] ipAndPortParts = ipAndPort.Split(',');
IPAddress uploadIP = IPAddress.Parse(ipAndPortParts[0] + "." + ipAndPortParts[1] + "." + ipAndPortParts[2] + "." + ipAndPortParts[3]);
int uploadPort = (Int32.Parse(ipAndPortParts[4]) * 256) + Int32.Parse(ipAndPortParts[5]);
Debug.Print("File upload port: " + uploadIP.ToString() + ":" + uploadPort);
return new IPEndPoint(uploadIP, uploadPort);
public static ServerReply getRemoteServerReply()
byte[] inBuffer = new byte[100];
if (clientSocket.Poll(10 * 1000 * 1000, SelectMode.SelectRead))
int count = clientSocket.Receive(inBuffer);
string str = new string(Encoding.UTF8.GetChars(inBuffer), 0, count);
Debug.Print("Remote server reply: " + str);
return new ServerReply(str, Int32.Parse(str.Substring(0, 3)));
throw new Exception("Timeout from FTP server");
public static ServerReply getRemoteServerReply(int expectedReplyCode)
ServerReply serverReply = getRemoteServerReply();
if (expectedReplyCode != serverReply.replyCode)
throw new Exception("Server returned: " + serverReply.replyCode + " " + serverReply.servereply + " Expected: " + expectedReplyCode);
return serverReply;
class ServerReply
string _serverReply;
int _replyCode;
public ServerReply(string serverReply, int replyCode)
_serverReply = serverReply;
_replyCode = replyCode;
public string servereply
get
return _serverReply;
public int replyCode
get
return _replyCode;
