I was going to do some work with my Panda II board to begin developing an altitude heading reference system. I connected the USB cable and connected an 8.4V battery to the power input. I checked the battery to make sure the advertised voltage was correct. It showed 8.57V, 0.1mA. I connected the 3V3 port to a breadboard + rail and made a continuous circuit back through to the GND port. The two components circle in yellow got very hot (smoke). I disconnected the board from the external power and the on board red LED came on for a second and I disconnected the board from USB. I let everything cool and now when I connect the panda to USB only, it is not recognized, no on board LED, nothing. I’m assuming that it is ruined. Where did I go wrong? Would I have been okay if I had had some sort of device in the circuit where I have the yellow arrow drawn? I don’t want to make this mistake again obviously. But I thought everything I’ve done here should not have caused this problem. Is is possible to replace the indicated components that got hot and salvage the board at least for development?
You would have also shorted the USB jack which has overload protection so you probably have to restart the computer before it detects anything plugged in that jack.
The way you describe it makes it seem like the 5V regulator through the power jack went into shutdown then started to sink through the USB. Then when you pull the power jack it takes a surge from USB for a second until the USB jack shuts down.
Unplug everything then just plug in through the power jack. If it comes on and has 3.3V output then it might be as minor as that diode. Then you test the diode by seeing if it has voltage between ground and 1 side of it but not the other.
keep panda plugged in, connect one side of meter to ground pin on header (GND) and with other multimeter wire measure the voltage on both sides of the diodes D2, D3 and D4.
Also, measure the voltage on pins 5V and 3,3V and VIN.
Yes, I understand. Thanks for the support. At this point the board is lost so I can’t make it any worse. I’m going to order another one for use in the quadcopter, but hate for this one to be a total loss if I can salvage it at least for a development board to program/test with or make a rolling robot for the kids.
I was able to get it to mount as a device and deploy code to it by supplying 3v (two AAA batteries) through the 3v3 pin at the top of the header. That’ll do!
