YES! It’s time for another contest! This would be a great way to generate some Gadgeteer buzz! (no, I’m not suggesting another piezo contest) I would recommend a general project contest based around some theme or a competition for the coolest way to achieve some task.
Here’s a new one… I tried doing a release build of your driver to generate the installer and I get this error…
[quote]"Error 1 The “Candle” task was not found. Check the following: 1.) The name of the task in the project file is the same as the name of the task class. 2.) The task class is “public” and implements the Microsoft.Build.Framework.ITask interface. 3.) The task is correctly declared with in the project file, or in the *.tasks files located in the “C:\Windows\Microsoft.NET\Framework\v4.0.30319” directory. D:\Temp\Buzzer Module\Buzzer\Buzzer\Buzzer.csproj 88 5 Buzzer
[/quote]
Would you mind adding the bug fix and sending me a new installer? I need to demo using the toolbar and it makes a god awful constant chirp w/o that fix
Will do, cant do untill i get into the office…
Unfortunately you have an original v1 with missing pull down…
What board do you get that on as i never had any issue with v1 on Cerb and only on premium boards as the pins are floating…
The problem is that I’m running it in a loop with a slider deciding the volume. If I have the slider down to zero then I still get a constant short chirp. I could put an if around the Buzz() call but I don’t want to have to explain that there’s a bug in your code I’m trying to make you look good, brother…
var timer = new GT.Timer(250);
timer.Tick += timer1 =>
_sliderPos = (int)(slider.GetSliderPosition()*100);
buzzer.Buzz(_sliderPos);
timer.Start();
I’ll answer this one for future reference. Typically ‘Candle’ errors are related to WIX which is used to build the installer which is why you only see it on ‘Release’ builds. Which version of WIX do you have installed, as I suspect Justin (and just about everyone else who builds installers for modules) uses the .NET Gadgeteer Builder Templates from the Gadgeteer CodePlex site (http://gadgeteer.codeplex.com/releases). Currently this template requires WIX 3.5 also from CodePlex (http://wix.codeplex.com/releases/view/60102). Once you have WIX 3.5 installed this error should go away.
Now if WPF was only so easy to explain, are there drugs that can help a person understand some of the inner workings of WPF?
