There is a rumor going around that the new SDK will be released in a matter of a day or two (Hopefully!)
And I have been waiting for a “Parellel Output Port” support for the LCD display for a while now!!
So I could do some Touch Screen LCD Application on Domino or Panda.
While I have been waiting, I created a library of icons, so I could use them as soon as the release of the update.
And I don’t mind to share this with all of you, who might also want to do the same thing!
Actually this icons library can also be use with the FEZ Cobra/ChipworkX board with LCD.
All the icons are in the same size (70x70 pixel) as the those that used in the GHI Graphical Demo.
The icons (40+) are both in Round Corner Rectangular shape and in Circular Shape.
You can download the icons library form here, (scroll down before “Download Project Files”:
Can you put png’s with transparent background? It would be easier to change background to something else other than the default black that you have there right now.
Architect:
It’s done!
I separated the icons library into two,
one is jpg format with black background and
the other is in png format with transparent background!
public void DrawImage(int x1, int y1, int x2, int y2, ushort[] pic)//, ts_mode_t mode)
LCD_CS.Write(false);
SetAddress(x1, y1, x2, y2);
int k=0;
int x = x2 - x1 + 1;
int y = y2 - y1 + 1;
for (int j = 0; j < y; j++)
for (int i = 0; i < x; i++)
WriteRegisterData((byte)(pic[k] >> 8), (byte)(pi[k]));
k++;
LCD_CS.Write(true);
the better route is to have the transparent background, so it will not get drawn.
