string zeroStr = "0";
double result = double.Parse(zeroStr) * -1;
Debug.Print(result.ToString());
…This results in -0. WTF? 0 * -1 = 0
I guess, technically, this could be true, since -0 IS the same as 0, but still… : :wall:
Not really a bug per se, it has to do with the way a signed number is stored. A signed number sets the high bit to indicate that the number is negative. For example a short could be 1000 0000 0000 0000, which is -0. But if you use a -0 in any other expression will get you the same thing as a regular old +0.
I think the issue is in the parse method. IT doesn’t happen if you don’t have that htere and you just say 0 * -1
Definitely a parse issue, there is no high bit on a string
But as long as it ONLY happens on zero it doesn’t matter.
Now if it does that for 1 somebody has some ‘splainin’ to do
This part “double.Parse(zeroStr)” evaluates to 0 when you then multiply it by -1 (which has high bit set) so you get -0. Strange but true, and it is not exclusive to one language or processor family.
I bet the other folks around here could come up with another few ways to generate a -0 as well. ;D
How to manufacture a -0:
Try this
double result = -0.0;
//double result = -0; // now try this one instead...
Debug.Print("(1) result = " + result.ToString());
result *= -1;
Debug.Print("(2) result = " + result.ToString());
Try both ways of instantiating ‘result’ and discover when the -0 is created in each case. Interesting? :o
Wait, but a minus times a minus is a positive…?
I wonder if it has to do with the double times an int.
If you made it result *= -1.0;
What happens?
What I’m getting at is that if you instantiate ‘result’ this way:
The first value printed out is -0, and the * -1 makes it a positive. if however you instantiate ‘result’ as:
double result = -0;
The first value printed out is 0, and the *-1 makes it a negative.
What does this tell us? Think about it before clicking on the answer below.
Here is the answer: [url]http://en.wikipedia.org/wiki/Signed_zero[/url]
We have passed this on to Microsoft and they will look into this for future builds
I think that finding a bug in Microsoft’s code demands some EX points Gus
It is NOT a bug, it’s a feature. :
It is required by IEEE 754 that floating point types support both + and - zero (link I posted above) here is a bit more information from MS about floating point types in C#: [url]Microsoft Learn: Build skills that open doors in your career
Actually they found out that the core C++ give this results so in a way, it is correct. But, this needs to match the big .NET so they will look into it.
Can you not use typed literals to generate zero?
double zero = 0D;
Andy
