Flex sensor
hello,
i connected a flex sensor : https://www.sparkfun.com/products/8606
to my fez panda 2.
but when i launch my debugging, after a moment i have an error with GHIElectronics.NETMF.Hardware.dll
and Debug.print, print nothing.
my code :
using System.Text;
using System.IO;
using Microsoft.SPOT.IO;
namespace FEZ_Panda_II_Application1
        public static void dP() {
             AnalogIn Flex = new AnalogIn((AnalogIn.Pin)FEZ_Pin.AnalogIn.An0);
             long voltage = Flex.Read();
             String ecrir = voltage.ToString();
             Debug.Print(ecrir);
                dP();
help plz
the error is linked to AnalogIn, but why ?
try to move “AnalogIn Flex = new AnalogIn((AnalogIn.Pin)FEZ_Pin.AnalogIn.An0);” outside of the method dp()…
            Debug.Print(ecrir);
                dP();
i moved all from dp() method to Main(), and it works ! Thanks !
YW :slight_smile:
