I have worked with most of the FEZ boards, and have never had an application memory issue. If I ever have a problem, I will find the answer.
It is really hard to run out of flash memory, where the applications reside.
For now, don’t worry… As you get more familiar with the micro framework, you will be able to read the information displayed during the upload process. The information is there.
BTW: The 148K flash number is the amount of flash that is available for the user. There is a lot more which is used for the .NET stuff.
I went to the ‘le’ folder and I found out the ‘FEZ Domino Application.pe’ only takes 20K;
I saw some errors in the output window concerning to the block allocation and I´ll use more often the GC;
