Well 2012 is interesting, but I donât want to install it again since I have been using 2013 for so long. I know sxs install works, but I donât want to chance it.
I hope the authorities that be will chime in and give instructions on my next steps.
Then installed these:
1 Microsoft .NET Micro Framework 4.3 (Framework) QFE1
Seems that QFE1 requires VS2012.
So I installed:
1 Microsoft .NET Micro Framework 4.3 (Framework) QFE2
2 Microsoft .NET Gadgeteer Core (Core)
3 NETMF and Gadgeteer Package 2014 R5 (SDK)
As of SDK 4.3.1 (R2) Microsoft Visual Studio is no longer required to install
the base SDK. However,to deploy and debug applications a supported version of
Visual Studio is required along with a project system extension for the .NET
Micro Framework (a.k.a VSIX package). To enable use of the .NET Micro Framework
with multiple versions of Visual Studio the Visual Studio integration and
project system are now separate and available from the Visual Studio Extension
Gallery.
To install the VSIX extension for .NET Micro Framework projects:
* From Visual studio main menu select âToolsâ
* select âExtensions and Updatesâ From the drop down menu to see available
extensions [ you can filter the view with the keyword âNETMFâ].
The Supported Versions of Visual Studio are:
* VS2012 (Pro,Ultimate, Express) * VS2013 (Pro, Ultimate, Express)
* VS14 CTP 2 (pre-release support only)
To allow use with existing firmware builds the actual framework revision remains
the same as the previous release (4.3.1) even though the SDK itself has a new
revision number."
[/quote]
So it looks like I didnt just click on the .vsix file, I added it using the âextensions and updatesâ menu option.
Also, is your version of vs2013 one of the supported versions? âvs2013 premiumâ and âvs2013 test Proâ and the âvs2013 onlineâ versions arent supported apparently
Edit: Oh⌠you said you already do netduino stuff⌠so this probably isnt your issue.
