Better: both. Because people will start making code and do not know why the SD card code gets stuck. If they see the warning, they can fix it.
[quote]
Better: both. Because people will start making code and do not know why the SD card code gets stuck. If they see the warning, they can fix it.[/quote]
If I understand correctly, this is hardware issue and will not affect future board revs, so it should be put in the rev specific manual.
Yes you are correct
KMartin,
If you think you see the same issue with other Cards, this does not mean that it is related to the same cause. There is always a place for software enhancement. So please don’t take the mentioned issue as a rule that can be applied always.
But of course you can try to add the 10uF capacitor to see if the problem with the verbatim disappears. your test result can help others too.
