Hi All,
I’ve just started to integration test the code I’ve written for Chipworkx
I’m seeing file writes taking quite some time:
PersistentStorage sdPS = new PersistentStorage("SD");
// Mount the file system
sdPS.MountFileSystem();
byte[] message = new byte[102400];
for (int i = 0; i < message.Length; i++)
message[i] = (byte)i;
Debug.Print("Writing Large File: " + System.DateTime.Now.ToString("T"));
WriteFile(@ "\SD\testFile.txt", message);
Debug.Print("Finished writing Large File: " + System.DateTime.Now.ToString("T"));
Console outputs the following in debug mode:
[italic]Writing Large File: 00:04:34
Writing File: \SD\testFile.txt
Finished writing Large File: 00:04:55
[/italic]
Hence it takes 21 seconds to write 100 kb = approx 4.76 kb per second
I would have expected at least 2mb /s
Is this common in the .net micro framework? Is there anything I can do to speed this up?
Thanks all :),
Ronan
