I have flashed 4.2 firmware includin network on my Hydra. I need to check some network routines in 4.2 rel. 15 june 2012
On the display the IP Address is garbled indicating “ip address: 192.168.20.677” instead of 192.168.20.67 that I’ve setup in MFDeploy. TCP/IP address is ok, and ping works fine in any case.
To update fw on Hydra with last beta, I’ve found that the following procedure works:
- Use boot.bin SD
- disconnect (power off) and on again. Then check if serial port installed (GPS com(x)).
- go to administrative command prompt and cd to GHI 4.2 directory installation ( …\GHI OSHW NETMF v4.2 SDK\FEZ Hydra\Firmware\FEZ Hydra TinyBooter Updater).
- run “updateFEZHydra.bat comx”
- monitor file “logfile.log” created in the directory. if it shows error for some reason, switch Hydra power off and on again then retry.
(5 again: may be you need to reboot more times here, before update will work) - correct procedure produce a logfile.log as show in the code.
- the hydra is now in tinybooter. Reboot again (cycle power off and on)
8.Check that it is installed as "Debuggable .NET Micro framework device"
9 start MFDeploy and load “ER_CONFIG” and “ER_FLASH” (net fw or no net fw), then press deploy. - Device is ready for use.
Just FYI
-I- Waiting ...
-I- TCL platform : Windows NT
-I- SAM-BA CDC 2.10 on : windows
-I- Retrieved arguments from command line :
-I- argv 0 : com12
-I- argv 1 : at91sam9rl64-ek
-I- argv 2 : TinyBooterLoader.tcl
-I- Connection : com12 (target(comType) = 3)
-I- Board : at91sam9rl64-ek
-I- Traces Level : 4
-I- target(handle) : file21f7780
Read device Chip ID at 0xfffff240 --- get 0x019b03a0
-I- Found processor : at91sam9rl64 (Chip ID : 0x019b03a0)
-I- Command line mode : Execute script file : TinyBooterLoader.tcl
-I---------------------------------
-I- GHI Electronics, FEZ Hydra -
-I- TinyBooter Updater Script -
-I Enable DataFlash
-I- DATAFLASH::Init 0 (trace level : 4)
-I- Loading applet isp-dataflash-fez_hydra.bin at address 0x300000
-I- Memory Size : 0x420000 bytes
-I- Buffer address : 0x302CD8
-I- Buffer size: 0x18C0 bytes
-I- Applet initialization done
-I- Erasing: 0x18C0 bytes at address 0x0
-I- Erasing: 0x18C0 bytes at address 0x18C0
-I- Erasing: 0x18C0 bytes at address 0x3180
-I- Erasing: 0x18C0 bytes at address 0x4A40
-I- Erasing: 0x18C0 bytes at address 0x6300
-I- Erasing: 0x18C0 bytes at address 0x41A540
-I- Erasing: 0x18C0 bytes at address 0x41BE00
-I- Erasing: 0x18C0 bytes at address 0x41D6C0
-I- Erasing: 0x18C0 bytes at address 0x41EF80
-I- Send File FEZ_HYDRA_TINYBOOTER.bin at address 0x8400
GENERIC::SendFile FEZ_HYDRA_TINYBOOTER.bin at address 0x8400
-I- File size : 0xEC28 byte(s)
-I- Writing: 0x18C0 bytes at 0x8400 (buffer addr : 0x302CD8)
-I- 0x18C0 bytes written by applet
-I- Writing: 0x18C0 bytes at 0x9CC0 (buffer addr : 0x302CD8)
-I- Writing: 0x18C0 bytes at 0xB580 (buffer addr : 0x302CD8)
-I- Writing: 0x18C0 bytes at 0xCE40 (buffer addr : 0x302CD8)
-I- Writing: 0x18C0 bytes at 0xE700 (buffer addr : 0x302CD8)
-I- Writing: 0x18C0 bytes at 0xFFC0 (buffer addr : 0x302CD8)
-I- Writing: 0x18C0 bytes at 0x11880 (buffer addr : 0x302CD8)
-I- Writing: 0x18C0 bytes at 0x13140 (buffer addr : 0x302CD8)
-I- Writing: 0x18C0 bytes at 0x14A00 (buffer addr : 0x302CD8)
-I- Writing: 0xD68 bytes at 0x162C0 (buffer addr : 0x302CD8)
-I- 0xD68 bytes written by applet
GENERIC::SendFile GHI_OSHW_BOOTSTRAP.bin at address 0x0
-I- File size : 0x2628 byte(s)
-I- Writing: 0x18C0 bytes at 0x0 (buffer addr : 0x302CD8)
-I- Writing: 0xD68 bytes at 0x18C0 (buffer addr : 0x302CD8)
-I- Script Completed -
-I- Please Reset the Device -
