Hi guys,
I’m experimenting with my Fez Panda (I) and an eBay LCD module that I changed from 16 to 8 bit parallel bus, similar to those used on the FEZ TOUCH (ILI9325 chipset), and that’s working perfectly with the drivers I found here.
I know that using only C# Fez Panda it’s not so fast to obtains a fast response Touch-GUI, also using the 8 bits fast mode Parallel Port, but I have not a fast response time problem, so I’m writing a class to create a simple Touch-GUI class for that display.
There are some utility program to create a simple Touch-GUI (button text, menu scrolling options) for those type of displays? Someone also had wrote a similar C#-class code?
Thanks.
Michele - Italy.
