If anyone is interested: I added also PortraitInverse to the FEZ Touch driver (Ver 2.2) as in my project it comes with the cable running away to my Panda II:
Copyright 2011 GHI Electronics LLC
Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License.
You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software distributed under the License is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND,
either express or implied. See the License for the specific language governing permissions and limitations under the License.
namespace GHIElectronics.NETMF.FEZ
public static partial class FEZ_Components
public class FEZTouch : IDisposable
#region Enumerated Values
public enum Orientation
Portrait = 0,
Landscape = 1,
LandscapeInverse = 2,
PortraitInverse = 3
public enum Color : ushort
White = 0xFFFF,
Black = 0x0000,
Red = (0xFF >> 3) | ((0 & 0xFC) << 3) | ((0 & 0xF8) << 8),
Blue = (0 >> 3) | ((0 & 0xFC) << 3) | ((0xFF & 0xF8) << 8),
Green = (0 >> 3) | ((0xFF & 0xFC) << 3) | ((0 & 0xF8) << 8),
Cyan = (0 >> 3) | ((0xFF & 0xFC) << 3) | ((0xFF & 0xF8) << 8),
Gray = (0x80 >> 3) | ((0x80 & 0xFC) << 3) | ((0x80 & 0xF8) << 8),
Magneta = (0xFF >> 3) | ((0 & 0xFC) << 3) | ((0xFF & 0xF8) << 8),
Yellow = (0xFF >> 3) | ((0xFF & 0xFC) << 3) | ((0 & 0xF8) << 8),
public enum PowerMode
Normal = 0,
Sleep = 1,
StandBy = 2,
DeepStandBy = 3
public enum DisplayMode
Normal = 0,
Dim = 1,
Off = 2
#endregion
#region Events
public delegate void TouchEventHandler(int x, int y);
public event TouchEventHandler TouchDownEvent = delegate { };
public event TouchEventHandler TouchMoveEvent = delegate { };
public event TouchEventHandler TouchUpEvent = delegate { };
#endregion
#region Constructors
protected FEZTouch()
// not allowed to call this constructor
public FEZTouch(LCDConfiguration lcdConfig)
this.InitLCD(lcdConfig);
public FEZTouch(LCDConfiguration lcdConfig, TouchConfiguration touchConfig)
this.InitTouch(touchConfig);
#endregion
#region Destructors
~FEZTouch()
this.Dispose();
public void Dispose()
if (this.disposed == false)
this.disposed = true;
if (this.spi != null)
this.terminateTouchThread = true;
this.touchThread.Join();
this.spi.Dispose();
this.touchIRQ.Dispose();
this.TouchDownEvent = null;
this.TouchMoveEvent = null;
this.TouchUpEvent = null;
this.parallelPort.Dispose();
this.lcdReset.Dispose();
this.lcdChipSelect.Dispose();
this.lcdRegSelect.Dispose();
this.lcdBackLight.Dispose();
#endregion
#region Properties
public int ScreenWidth
get
switch (this.lcdOrientation)
case Orientation.Landscape:
case Orientation.LandscapeInverse:
return 320;
default:
return 240;
public int ScreenHeight
get
return 240;
default:
return 320;
public Orientation actOrientation
get { return this.lcdOrientation; }
#endregion
#region Control Methods
private void InitLCD(LCDConfiguration lcdConfig)
// save config values
this.parallelPort = new ParallelPort(lcdConfig.DataPins, lcdConfig.WritePin, lcdConfig.ReadPin);
this.lcdReset = new OutputPort(lcdConfig.Reset, true);
this.lcdChipSelect = new OutputPort(lcdConfig.ChipSelect, true);
this.lcdRegSelect = new OutputPort(lcdConfig.RS, true);
this.lcdBackLight = new OutputCompare(lcdConfig.BackLight, true, 2);
this.lcdOrientation = lcdConfig.LCDOrientation;
// set initial power and display modes
this.displayMode = DisplayMode.Normal;
this.backlightLevel = 100;
// toggle reset pin
this.lcdReset.Write(true);
Thread.Sleep(5);
this.lcdReset.Write(false);
Thread.Sleep(5);
Thread.Sleep(5);
this.lcdChipSelect.Write(false);
//************* Start Initial Sequence **********//
this.WriteRegister(0x01, 0x0100); // set SS and SM bit
this.WriteRegister(0x02, 0x0200); // set 1 line inversion
case Orientation.Portrait:
// AM = 0
// ID1-ID0 = 10
// ORG = 1
// HWM = 1
this.WriteRegister(0x03, 0x0230);
break;
// AM = 1
// ID1-ID0 = 11
// ORG = 0
// HWM = 1
this.WriteRegister(0x03, 0x02A8);
break;
// AM = 1
// ID1-ID0 = 01
// ORG = 0
// HWM = 1
this.WriteRegister(0x03, 0x0298);
break;
case Orientation.PortraitInverse:
// AM = 0
// ID1-ID0 = 00
// ORG = 0
// HWM = 1
this.WriteRegister(0x03, 0x0200);
break;
this.WriteRegister(0x04, 0x0000); // Resize register
this.WriteRegister(0x08, 0x0207); // set the back porch and front porch
this.WriteRegister(0x09, 0x0000); // set non-display area refresh cycle ISC[3:0]
this.WriteRegister(0x0A, 0x0000); // FMARK function
this.WriteRegister(0x0C, 0x0000); // RGB interface setting
this.WriteRegister(0x0D, 0x0000); // Frame marker Position
this.WriteRegister(0x0F, 0x0000); // RGB interface polarity
//*************Power On sequence ****************//
this.WriteRegister(0x10, 0x0000); // SAP, BT[3:0], AP, DSTB, SLP, STB
this.WriteRegister(0x11, 0x0007); // DC1[2:0], DC0[2:0], VC[2:0]
this.WriteRegister(0x12, 0x0000); // VREG1OUT voltage
this.WriteRegister(0x13, 0x0000); // VDV[4:0] for VCOM amplitude
this.WriteRegister(0x07, 0x0001);
Thread.Sleep(200); // Dis-charge capacitor power voltage
this.WriteRegister(0x10, 0x1690); // SAP, BT[3:0], AP, DSTB, SLP, STB
this.WriteRegister(0x11, 0x0227); // Set DC1[2:0], DC0[2:0], VC[2:0]
Thread.Sleep(50); // Delay 50ms
this.WriteRegister(0x12, 0x000D); // 0012
this.WriteRegister(0x13, 0x1200); // VDV[4:0] for VCOM amplitude
this.WriteRegister(0x29, 0x000A); // 04 VCM[5:0] for VCOMH
this.WriteRegister(0x2B, 0x000D); // Set Frame Rate
Thread.Sleep(50); // delay 50ms
this.WriteRegister(0x20, 0x0000); // GRAM horizontal Address
this.WriteRegister(0x21, 0x0000); // GRAM Vertical Address
// ----------- Adjust the Gamma Curve ----------//
this.WriteRegister(0x30, 0x0000);
this.WriteRegister(0x31, 0x0404);
this.WriteRegister(0x32, 0x0003);
this.WriteRegister(0x35, 0x0405);
this.WriteRegister(0x36, 0x0808);
this.WriteRegister(0x37, 0x0407);
this.WriteRegister(0x38, 0x0303);
this.WriteRegister(0x39, 0x0707);
this.WriteRegister(0x3C, 0x0504);
this.WriteRegister(0x3D, 0x0808);
//------------------ Set GRAM area ---------------//
this.WriteRegister(0x50, 0x0000); // Horizontal GRAM Start Address
this.WriteRegister(0x51, 0x00EF); // Horizontal GRAM End Address
this.WriteRegister(0x52, 0x0000); // Vertical GRAM Start Address
this.WriteRegister(0x53, 0x013F); // Vertical GRAM Start Address
this.WriteRegister(0x60, 0xA700); // Gate Scan Line
this.WriteRegister(0x61, 0x0001); // NDL, VLE, REV
this.WriteRegister(0x6A, 0x0000); // set scrolling line
//-------------- Partial Display Control ---------//
this.WriteRegister(0x80, 0x0000);
this.WriteRegister(0x81, 0x0000);
this.WriteRegister(0x82, 0x0000);
this.WriteRegister(0x83, 0x0000);
this.WriteRegister(0x84, 0x0000);
this.WriteRegister(0x85, 0x0000);
//-------------- Panel Control -------------------//
this.WriteRegister(0x90, 0x0010);
this.WriteRegister(0x92, 0x0000);
this.WriteRegister(0x07, 0x0133); // 262K color and display ON
this.lcdChipSelect.Write(true);
private void InitTouch(TouchConfiguration touchConfig)
this.spi = new SPI(new SPI.Configuration(touchConfig.ChipSelect, false, 1, 1, false, true, 2000, touchConfig.Channel));
this.touchIRQ = new InputPort(touchConfig.TouchIRQ, false, Port.ResistorMode.Disabled);
this.terminateTouchThread = false;
this.touchThread = new Thread(this.TouchThread);
this.touchThread.Priority = ThreadPriority.Highest;
this.touchThread.Start();
public void SetPowerMode(PowerMode powerMode)
if (this.powerMode != powerMode)
// save power mode
this.powerMode = powerMode;
// set new power mode
switch (this.powerMode)
case PowerMode.Normal:
break;
case PowerMode.Sleep:
this.WriteRegister(0x10, 0x1691);
break;
case PowerMode.StandBy:
this.WriteRegister(0x10, 0x1692);
break;
case PowerMode.DeepStandBy:
this.WriteRegister(0x10, 0x1694);
break;
public void SetDisplayMode(DisplayMode displayMode)
if (this.displayMode != displayMode)
// save display mode
this.displayMode = displayMode;
// set new display mode
switch (this.displayMode)
case DisplayMode.Normal:
this.SetBackLightLevel(100);
break;
case DisplayMode.Dim:
this.SetBackLightLevel(5);
break;
case DisplayMode.Off:
this.SetBackLightLevel(0);
this.WriteRegister(0x07, 0x0131);
break;
public void SetBackLightLevel(int backlightLevel)
// check for valid parameters
if (backlightLevel < 0 || backlightLevel > 100)
throw new ArgumentException();
if (this.backlightLevel != backlightLevel)
// save back light level
this.backlightLevel = backlightLevel;
// set new back light level
if (this.backlightLevel == 0)
this.lcdBackLight.Set(false);
else if (this.backlightLevel == 100)
this.lcdBackLight.Set(true);
const int PERIOD = 10000;
int highTime = PERIOD * this.backlightLevel / 100;
this.lcdBackLight.Set(true, new uint[2] { (uint)highTime, (uint)(PERIOD - highTime) }, 0, 2, true);
#endregion
#region Drawing Methods
public void ClearScreen()
this.FillRectangle(0, 0, this.ScreenWidth, this.ScreenHeight, FEZ_Components.FEZTouch.Color.Black); // fill screen with black
public Color ColorFromRGB(byte red, byte green, byte blue)
return (Color)((red >> 3) | ((green & 0xFC) << 3) | ((blue & 0xF8) << 8));
private void SetPixelAddress(int x, int y)
this.WriteRegister(0x20, (ushort)x);
this.WriteRegister(0x21, (ushort)y);
private void SetDrawingWindow(int x, int y, int width, int height)
// pixel address
this.SetPixelAddress(x, y);
// window
this.WriteRegister(0x50, (ushort)x);
this.WriteRegister(0x52, (ushort)y);
this.WriteRegister(0x51, (ushort)(x + width - 1));
this.WriteRegister(0x53, (ushort)(y + height - 1));
public void SetPixel(int x, int y, Color color)
if (x < 0 || y < 0 || x >= this.ScreenWidth || y >= this.ScreenHeight)
throw new ArgumentException("SetPixel: Invalid parameter values.");
this.buffer[0] = (byte)((int)color >> 8);
this.buffer[1] = (byte)(color);
this.SetDrawingWindow(x, y, 1, 1);
this.SetRegister(REGISTER_WRITE_GRAM);
this.parallelPort.Write(this.buffer, 0, 2);
public void DrawLine(int xStart, int yStart, int xEnd, int yEnd, Color color)
if (xStart < 0 || yStart < 0 || xStart >= this.ScreenWidth || yStart >= this.ScreenHeight)
throw new ArgumentException("DrawLine: Invalid start position values.");
if (xEnd < 0 || yEnd < 0 || xEnd >= this.ScreenWidth || yEnd >= this.ScreenHeight)
throw new ArgumentException("DrawLine: Invalid end position values.");
// translate coordinates based on display orientation
int x0 = 0;
int y0 = 0;
int x1 = 0;
int y1 = 0;
x0 = xStart;
y0 = yStart;
x1 = xEnd;
y1 = yEnd;
break;
x0 = SCREEN_WIDTH - yStart - 1;
y0 = xStart;
x1 = SCREEN_WIDTH - yEnd - 1;
y1 = xEnd;
break;
x0 = yStart;
y0 = SCREEN_HEIGHT - xStart - 1;
x1 = yEnd;
y1 = SCREEN_HEIGHT - xEnd - 1;
break;
x0 = SCREEN_WIDTH - xStart - 1;
y0 = SCREEN_HEIGHT - yStart - 1;
x1 = SCREEN_WIDTH - xEnd - 1;
y1 = SCREEN_HEIGHT - yEnd - 1;
break;
int dy = y1 - y0;
int dx = x1 - x0;
float m = 0;
int b = 0;
if (dx != 0)
m = ((float)(dy)) / (dx);
b = y0 - (int)(m * x0);
if (global::System.Math.Abs(dx) >= global::System.Math.Abs(dy))
if (x0 > x1)
this.Swap(ref x0, ref x1);
this.Swap(ref y0, ref y1);
while (x0 <= x1)
this.SetDrawingWindow(x0, y0, 1, 1);
x0++;
if (x0 <= x1)
y0 = (int)(m * x0) + b;
if (y0 > y1)
while (y0 <= y1)
y0++;
if (y0 <= y1)
if (dx != 0)
x0 = (int)((float)(y0 - b) / m);
public void FillRectangle(int xPos, int yPos, int rectWidth, int rectHeight, Color color)
// validate parameter values
if (xPos < 0 || yPos < 0 || (xPos + rectWidth) > this.ScreenWidth || (yPos + rectHeight) > this.ScreenHeight)
throw new ArgumentException("FillRectangle: Invalid parameter values.");
int x = 0;
int y = 0;
int width = 0;
int height = 0;
x = xPos;
y = yPos;
width = rectWidth;
height = rectHeight;
break;
x = SCREEN_WIDTH - yPos - rectHeight;
y = xPos;
width = rectHeight;
height = rectWidth;
break;
x = yPos;
y = SCREEN_HEIGHT - xPos - rectWidth;
width = rectHeight;
height = rectWidth;
break;
x = SCREEN_WIDTH - xPos - rectWidth;
y = SCREEN_HEIGHT - yPos - rectHeight;
width = rectWidth;
break;
int pixelCount = width * height;
int bufferPixels = this.buffer.Length / 2; // every pixel is 2 bytes
byte h = (byte)((int)color >> 8);
byte l = (byte)(color);
// fill buffer
for (int i = 0; i < this.buffer.Length; i = i + 2)
this.buffer[i] = h;
this.buffer[i + 1] = l;
this.SetDrawingWindow(x, y, width, height);
int loops = pixelCount / bufferPixels;
for (int i = 0; i < loops; i++)
this.parallelPort.Write(this.buffer, 0, this.buffer.Length);
int pixelsLeft = pixelCount % bufferPixels;
if (pixelsLeft > 0)
this.parallelPort.Write(this.buffer, 0, pixelsLeft * 2);
public void DrawImage(int xPos, int yPos, Image image)
if (xPos < 0 || yPos < 0 || (xPos + image.Width) > this.ScreenWidth || (yPos + image.Height) > this.ScreenHeight)
throw new ArgumentException("DrawImage: Invalid parameter values.");
int x = 0;
int y = 0;
int width = 0;
int height = 0;
x = xPos;
y = yPos;
width = image.Width;
height = image.Height;
break;
x = SCREEN_WIDTH - yPos - image.Height;
y = xPos;
width = image.Height;
height = image.Width;
break;
x = yPos;
y = SCREEN_HEIGHT - xPos - image.Width;
break;
x = SCREEN_WIDTH - xPos - image.Width;
y = SCREEN_HEIGHT - yPos - image.Height;
break;
this.parallelPort.Write(image.ImageBytes, Image.IMG_PIXELS_INDEX, image.ImageBytes.Length - Image.IMG_PIXELS_INDEX);
public void DrawString(int xPos, int yPos, string text, Color fgColor, Color bgColor, Font font)
if (xPos < 0 || yPos < 0)
throw new ArgumentException("DrawString: Screen position (x,y) is invalid.");
if ((xPos + font.GetTextWidth(text)) > this.ScreenWidth || (yPos + font.Height) > this.ScreenHeight)
throw new ArgumentException("DrawString: Text string is too wide or too high to fit on the screen.");
int x = 0;
int y = 0;
int width = 0;
int height = 0;
x = xPos;
y = yPos;
break;
x = SCREEN_WIDTH - yPos - font.Height;
y = xPos;
break;
x = yPos;
y = SCREEN_HEIGHT - xPos - font.AverageWidth;
break;
x = SCREEN_WIDTH - xPos - font.AverageWidth;
y = SCREEN_HEIGHT - yPos - font.Height;
break;
// split colors into bytes
byte fgColorHigh = (byte)((int)fgColor >> 8);
byte fgColorLow = (byte)(fgColor);
byte bgColorHigh = (byte)((int)bgColor >> 8);
byte bgColorLow = (byte)(bgColor);
// draw each character
char currentChar = ' ';
CharInfo charInfo = null;
int bytesInBuffer = 0;
for (int charIndex = 0; charIndex < text.Length; charIndex++)
// get character
currentChar = text[charIndex];
// get character info
charInfo = font[currentChar];
// translate width and height based on display orientation
width = charInfo.Width;
height = charInfo.Height;
break;
width = charInfo.Height;
height = charInfo.Width;
break;
// get character pixels
bytesInBuffer = font.FillBitmapBuffer(charInfo, this.buffer, fgColorLow, fgColorHigh, bgColorLow, bgColorHigh);
// output character pixels
this.parallelPort.Write(this.buffer, 0, bytesInBuffer);
// update x position
x += width;
break;
y += height;
break;
y -= height;
break;
x -= width;
break;
#endregion
#region Interface Methods
private void Swap(ref int a1, ref int a2)
int temp = a1;
a1 = a2;
a2 = temp;
private void SetRegister(byte register)
this.lcdRegSelect.Write(false);
this.regBuffer[0] = 0;
this.regBuffer[1] = register;
this.parallelPort.Write(this.regBuffer, 0, 2);
this.lcdRegSelect.Write(true);
private void WriteRegister(byte register, ushort value)
this.SetRegister(register);
this.regBuffer[0] = (byte)(value >> 8);
this.regBuffer[1] = (byte)(value);
this.parallelPort.Write(regBuffer, 0, 2);
#endregion
#region Touch Thread & Methods
private void TouchThread()
int lastX = 0;
int lastY = 0;
bool lastStatus = false; // true means there are touches
int x;
int y;
bool status;
byte[] writeBuffer = new byte[] { 0, 0, 0, 0 };
byte[] readBuffer = new byte[2];
while (this.terminateTouchThread == false)
Thread.Sleep(TOUCH_SAMPLING_TIME);
status = !this.touchIRQ.Read();
if (status == true)
writeBuffer[0] = 0x90;
this.spi.WriteRead(writeBuffer, readBuffer, 1);
y = readBuffer[0];
y <<= 8;
y |= readBuffer[1];
y >>= 3;
writeBuffer[0] = 0xD0;
x = readBuffer[0];
x <<= 8;
x |= readBuffer[1];
x >>= 3;
// calibrate
if (x > 3750)
x = 3750;
else if (x < 280)
x = 280;
if (y > 3850)
y = 3850;
else if (y < 450)
y = 450;
x = (3750 - x) * (SCREEN_WIDTH - 1) / (3750 - 280);
y = (3850 - y) * (SCREEN_HEIGHT - 1) / (3850 - 450);
if (lastStatus == false)
this.FireTouchDownEvent(x, y);
lastStatus = true;
lastX = x;
lastY = y;
// filter small changes
if (global::System.Math.Abs(x - lastX) > 5 || global::System.Math.Abs(y - lastY) > 5)
this.FireTouchMoveEvent(x, y);
lastX = x;
lastY = y;
else if (lastStatus == true)
this.FireTouchUpEvent(lastX, lastY);
lastStatus = false;
private void FireTouchDownEvent(int xPos, int yPos)
if (this.TouchDownEvent != null)
int x = 0;
int y = 0;
x = xPos;
y = yPos;
break;
x = yPos;
y = SCREEN_WIDTH - xPos - 1;
break;
x = SCREEN_HEIGHT - yPos - 1;
y = xPos;
break;
x = SCREEN_WIDTH - xPos - 1;
y = SCREEN_HEIGHT - yPos - 1;
break;
// fire the event
this.TouchDownEvent(x, y);
private void FireTouchMoveEvent(int xPos, int yPos)
if (this.TouchMoveEvent != null)
int x = 0;
int y = 0;
x = xPos;
y = yPos;
break;
x = yPos;
break;
y = xPos;
break;
break;
// fire the event
this.TouchMoveEvent(x, y);
private void FireTouchUpEvent(int xPos, int yPos)
if (this.TouchUpEvent != null)
int x = 0;
int y = 0;
x = xPos;
y = yPos;
break;
x = yPos;
break;
y = xPos;
break;
break;
// fire the event
this.TouchUpEvent(x, y);
#endregion
#region Font Classes
public class Font
// CONSTRUCTORS
protected Font()
// this constructor is not for external access
this.avgWidth = 0;
this.maxWidth = 0;
this.height = 0;
this.startChar = '\x00';
this.endChar = '\x00';
this.charDescriptors = null;
this.charBitmaps = null;
// PROPERTIES
public ushort AverageWidth
get { return this.avgWidth; }
public ushort MaxWidth
get { return this.maxWidth; }
public ushort Height
get { return this.height; }
public CharInfo this[char newChar]
get
if (newChar < this.startChar || newChar > this.endChar)
throw new ArgumentException("Font class: character not found.");
ushort bitMask = 0x7FFF;
int descriptorIndex = (newChar - this.startChar) * constSizeOfCharDescriptor;
ushort charWidth = (ushort)(this.charDescriptors[descriptorIndex] & bitMask);
ushort charHeight = (ushort)(this.charDescriptors[descriptorIndex + 1] & bitMask);
ushort bitmapStartIndex = (ushort)(this.charDescriptors[descriptorIndex + 2] & bitMask);
ushort bitmapLength = (ushort)(this.charDescriptors[descriptorIndex + 3] & bitMask);
return new CharInfo(newChar, charWidth, charHeight, bitmapStartIndex, bitmapLength);
// METHODS
public int GetTextWidth(string text)
int totalPixels = 0;
foreach (char character in text)
totalPixels += this[character].Width;
return totalPixels;
public int FillBitmapBuffer(CharInfo charInfo, byte[] buffer, byte fgColorLow, byte fgColorHigh, byte bgColorLow, byte bgColorHigh)
// check the buffer size
int charBytesReq = charInfo.Width * charInfo.Height * 2;
int totalBytesReq = charInfo.Width * this.height * 2;
if (buffer.Length < totalBytesReq)
throw new ArgumentException("Buffer length is not large enough for this character.");
// fill the buffer
ushort bitmapValue = 0;
int bufferIndex = 0;
ushort bitmapIndex = charInfo.BitmapStartIndex;
for (int i = 0; i < charInfo.BitmapLength; i++, bitmapIndex++)
bitmapValue = (ushort)this.charBitmaps[bitmapIndex];
for (ushort bitMask = (ushort)0x0001; bitMask < (ushort)0x8000; )
// add pixel color
if ((bitmapValue & bitMask) == bitMask)
// add foreground color
buffer[bufferIndex] = fgColorHigh;
buffer[bufferIndex + 1] = fgColorLow;
// add background color
buffer[bufferIndex] = bgColorHigh;
buffer[bufferIndex + 1] = bgColorLow;
// adjust bitMask, increment pixelsRead, and increment bufferIndex
bitMask = (ushort)(bitMask << 1);
bufferIndex += 2;
// check if we are done
if (bufferIndex >= charBytesReq)
break;
// add blank rows
while (bufferIndex < totalBytesReq)
bufferIndex += 2;
// return num bytes in buffer
return bufferIndex;
// MEMBER FIELDS
protected ushort avgWidth;
protected ushort maxWidth;
protected ushort height;
protected char startChar;
protected char endChar;
protected string charDescriptors;
protected string charBitmaps;
protected const int constSizeOfCharDescriptor = 4; // number of chars in each descriptor
public class CharInfo
// CONSTRUCTORS
public CharInfo(char character, ushort charWidth, ushort charHeight, ushort bitmapStartIndex, ushort bitmapLength)
this.character = character;
this.charWidth = charWidth;
this.charHeight = charHeight;
this.bitmapStartIndex = bitmapStartIndex;
this.bitmapLength = bitmapLength;
// PROPERTIES
public char Character
get { return this.character; }
public ushort Width
get { return this.charWidth; }
get { return this.charHeight; }
public ushort BitmapStartIndex
get { return this.bitmapStartIndex; }
public ushort BitmapLength
get { return this.bitmapLength; }
// MEMBER FIELDS
private char character;
private ushort charWidth;
private ushort charHeight;
private ushort bitmapStartIndex;
private ushort bitmapLength;
#endregion
#region Image Class
public class Image
// CONSTRUCTORS
public Image(byte[] imgBytes)
if (Utility.ExtractValueFromArray(imgBytes, 0, 4) != SIGNATURE)
throw new ArgumentException("Image Class: Signature bytes not found.");
int width = (int)Utility.ExtractValueFromArray(imgBytes, 4, 2);
int height = (int)Utility.ExtractValueFromArray(imgBytes, 6, 2);
if (width * height * 2 + 8 != imgBytes.Length)
throw new ArgumentException("Image class: Width and height do not match size of byte array.");
this.ImageBytes = imgBytes;
this.Width = width;
this.Height = height;
// PROPERTIES
public readonly int Width;
public readonly int Height;
public const uint SIGNATURE = 0x354A82B8;
public const int IMG_PIXELS_INDEX = 8;
public byte[] ImageBytes;
#endregion
#region LCD Configuration Class
public class LCDConfiguration
// CONSTRUCTORS
public LCDConfiguration(FEZ_Pin.Digital reset,
FEZ_Pin.Digital chipSelect,
FEZ_Pin.Digital RS,
FEZ_Pin.Digital lcdBackLight,
FEZ_Pin.Digital[] dataPins,
FEZ_Pin.Digital writePin,
FEZ_Pin.Digital readPin,
Orientation lcdOrientation)
this.DataPins = new Cpu.Pin[8];
for (int i = 0; i < 8; i++)
this.DataPins[i] = (Cpu.Pin)dataPins[i];
this.WritePin = (Cpu.Pin)writePin;
this.ReadPin = (Cpu.Pin)readPin;
this.ChipSelect = (Cpu.Pin)chipSelect;
this.Reset = (Cpu.Pin)reset;
this.RS = (Cpu.Pin)RS;
this.BackLight = (Cpu.Pin)lcdBackLight;
this.LCDOrientation = lcdOrientation;
// PROPERTIES
public Cpu.Pin[] DataPins;
public Cpu.Pin WritePin;
public Cpu.Pin ReadPin;
public Cpu.Pin ChipSelect;
public Cpu.Pin Reset;
public Cpu.Pin RS;
public Cpu.Pin BackLight;
public Orientation LCDOrientation;
#endregion
#region Touch Configuration Class
public class TouchConfiguration
public SPI.SPI_module Channel;
public Cpu.Pin TouchIRQ;
public TouchConfiguration(SPI.SPI_module channel, FEZ_Pin.Digital chipSelect, FEZ_Pin.Digital touchIRQ)
this.Channel = channel;
this.TouchIRQ = (Cpu.Pin)touchIRQ;
#endregion
#region Member Fields
// constants
private const int SCREEN_WIDTH = 240;
private const int SCREEN_HEIGHT = 320;
private const int BUFFER_SIZE = 2024;
private const byte REGISTER_WRITE_GRAM = 0x22;
private const int TOUCH_SAMPLING_TIME = 10;
private bool disposed = false;
private byte[] buffer = new byte[BUFFER_SIZE];
private byte[] regBuffer = new byte[2];
// lcd configuration
private ParallelPort parallelPort;
private OutputPort lcdReset;
private OutputPort lcdChipSelect;
private OutputPort lcdRegSelect;
private OutputCompare lcdBackLight;
private Orientation lcdOrientation;
// touch configuration
private SPI spi;
private InputPort touchIRQ;
private bool terminateTouchThread;
private Thread touchThread;
// display mode
private DisplayMode displayMode;
private int backlightLevel;
#endregion
