here is jasdevs FEZ TouchDriver 2.2 with IRQ-driven TouchEvent as described in this thread above. I do not know how to emplement it in the code site…
Copyright 2011 GHI Electronics LLC
namespace GHIElectronics.NETMF.FEZ
public static partial class FEZ_Components
public class FEZTouch : IDisposable
#region Enumerated Values
public enum Orientation
Portrait = 0,
Landscape = 1,
LandscapeInverse = 2
public enum Color : ushort
White = 0xFFFF,
Black = 0x0000,
Red = (0xFF >> 3) | ((0 & 0xFC) << 3) | ((0 & 0xF8) << 8),
Blue = (0 >> 3) | ((0 & 0xFC) << 3) | ((0xFF & 0xF8) << 8),
Green = (0 >> 3) | ((0xFF & 0xFC) << 3) | ((0 & 0xF8) << 8),
Cyan = (0 >> 3) | ((0xFF & 0xFC) << 3) | ((0xFF & 0xF8) << 8),
Gray = (0x80 >> 3) | ((0x80 & 0xFC) << 3) | ((0x80 & 0xF8) << 8),
Magneta = (0xFF >> 3) | ((0 & 0xFC) << 3) | ((0xFF & 0xF8) << 8),
Yellow = (0xFF >> 3) | ((0xFF & 0xFC) << 3) | ((0 & 0xF8) << 8),
public enum PowerMode
Normal = 0,
Sleep = 1,
StandBy = 2,
DeepStandBy = 3
public enum DisplayMode
Normal = 0,
Dim = 1,
Off = 2
#endregion
#region Events
public delegate void TouchEventHandler(int x, int y);
public event TouchEventHandler TouchDownEvent = delegate { };
public event TouchEventHandler TouchMoveEvent = delegate { };
public event TouchEventHandler TouchUpEvent = delegate { };
#endregion
#region Constructors
protected FEZTouch()
// not allowed to call this constructor
public FEZTouch(LCDConfiguration lcdConfig)
this.InitLCD(lcdConfig);
public FEZTouch(LCDConfiguration lcdConfig, TouchConfiguration touchConfig)
this.InitTouch(touchConfig);
#endregion
#region Destructors
~FEZTouch()
this.Dispose();
public void Dispose()
if (this.disposed == false)
this.disposed = true;
if (spi != null)
terminateTouchThread = true;
touchThread.Join();
spi.Dispose();
touchIRQ.Dispose();
this.TouchDownEvent = null;
this.TouchMoveEvent = null;
this.TouchUpEvent = null;
this.parallelPort.Dispose();
this.lcdReset.Dispose();
this.lcdChipSelect.Dispose();
this.lcdRegSelect.Dispose();
this.lcdBackLight.Dispose();
#endregion
#region Properties
public int ScreenWidth
get { return (this.lcdOrientation == Orientation.Portrait ? 240 : 320); }
public int ScreenHeight
get { return (this.lcdOrientation == Orientation.Portrait ? 320 : 240); }
#endregion
#region Control Methods
private void InitLCD(LCDConfiguration lcdConfig)
// save config values
this.parallelPort = new ParallelPort(lcdConfig.DataPins, lcdConfig.WritePin, lcdConfig.ReadPin);
this.lcdReset = new OutputPort(lcdConfig.Reset, true);
this.lcdChipSelect = new OutputPort(lcdConfig.ChipSelect, true);
this.lcdRegSelect = new OutputPort(lcdConfig.RS, true);
this.lcdBackLight = new OutputCompare(lcdConfig.BackLight, true, 2);
this.lcdOrientation = lcdConfig.LCDOrientation;
// set initial power and display modes
this.displayMode = DisplayMode.Normal;
this.backlightLevel = 100;
// toggle reset pin
this.lcdReset.Write(true);
Thread.Sleep(5);
this.lcdReset.Write(false);
Thread.Sleep(5);
Thread.Sleep(5);
this.lcdChipSelect.Write(false);
//************* Start Initial Sequence **********//
this.WriteRegister(0x01, 0x0100); // set SS and SM bit
this.WriteRegister(0x02, 0x0200); // set 1 line inversion
switch (this.lcdOrientation)
case Orientation.Portrait:
// AM = 0
// ID1-ID0 = 10
// ORG = 1
// HWM = 1
this.WriteRegister(0x03, 0x0230);
break;
case Orientation.Landscape:
// AM = 1
// ID1-ID0 = 11
// ORG = 0
// HWM = 1
this.WriteRegister(0x03, 0x02A8);
break;
case Orientation.LandscapeInverse:
// AM = 1
// ID1-ID0 = 01
// ORG = 0
// HWM = 1
this.WriteRegister(0x03, 0x0298);
break;
this.WriteRegister(0x04, 0x0000); // Resize register
this.WriteRegister(0x08, 0x0207); // set the back porch and front porch
this.WriteRegister(0x09, 0x0000); // set non-display area refresh cycle ISC[3:0]
this.WriteRegister(0x0A, 0x0000); // FMARK function
this.WriteRegister(0x0C, 0x0000); // RGB interface setting
this.WriteRegister(0x0D, 0x0000); // Frame marker Position
this.WriteRegister(0x0F, 0x0000); // RGB interface polarity
//*************Power On sequence ****************//
this.WriteRegister(0x10, 0x0000); // SAP, BT[3:0], AP, DSTB, SLP, STB
this.WriteRegister(0x11, 0x0007); // DC1[2:0], DC0[2:0], VC[2:0]
this.WriteRegister(0x12, 0x0000); // VREG1OUT voltage
this.WriteRegister(0x13, 0x0000); // VDV[4:0] for VCOM amplitude
this.WriteRegister(0x07, 0x0001);
Thread.Sleep(200); // Dis-charge capacitor power voltage
this.WriteRegister(0x10, 0x1690); // SAP, BT[3:0], AP, DSTB, SLP, STB
this.WriteRegister(0x11, 0x0227); // Set DC1[2:0], DC0[2:0], VC[2:0]
Thread.Sleep(50); // Delay 50ms
this.WriteRegister(0x12, 0x000D); // 0012
this.WriteRegister(0x13, 0x1200); // VDV[4:0] for VCOM amplitude
this.WriteRegister(0x29, 0x000A); // 04 VCM[5:0] for VCOMH
this.WriteRegister(0x2B, 0x000D); // Set Frame Rate
Thread.Sleep(50); // delay 50ms
this.WriteRegister(0x20, 0x0000); // GRAM horizontal Address
this.WriteRegister(0x21, 0x0000); // GRAM Vertical Address
// ----------- Adjust the Gamma Curve ----------//
this.WriteRegister(0x30, 0x0000);
this.WriteRegister(0x31, 0x0404);
this.WriteRegister(0x32, 0x0003);
this.WriteRegister(0x35, 0x0405);
this.WriteRegister(0x36, 0x0808);
this.WriteRegister(0x37, 0x0407);
this.WriteRegister(0x38, 0x0303);
this.WriteRegister(0x39, 0x0707);
this.WriteRegister(0x3C, 0x0504);
this.WriteRegister(0x3D, 0x0808);
//------------------ Set GRAM area ---------------//
this.WriteRegister(0x50, 0x0000); // Horizontal GRAM Start Address
this.WriteRegister(0x51, 0x00EF); // Horizontal GRAM End Address
this.WriteRegister(0x52, 0x0000); // Vertical GRAM Start Address
this.WriteRegister(0x53, 0x013F); // Vertical GRAM Start Address
this.WriteRegister(0x60, 0xA700); // Gate Scan Line
this.WriteRegister(0x61, 0x0001); // NDL, VLE, REV
this.WriteRegister(0x6A, 0x0000); // set scrolling line
//-------------- Partial Display Control ---------//
this.WriteRegister(0x80, 0x0000);
this.WriteRegister(0x81, 0x0000);
this.WriteRegister(0x82, 0x0000);
this.WriteRegister(0x83, 0x0000);
this.WriteRegister(0x84, 0x0000);
this.WriteRegister(0x85, 0x0000);
//-------------- Panel Control -------------------//
this.WriteRegister(0x90, 0x0010);
this.WriteRegister(0x92, 0x0000);
this.WriteRegister(0x07, 0x0133); // 262K color and display ON
this.lcdChipSelect.Write(true);
private void touch_OnInterrupt(uint iPort, uint iState, DateTime time)
terminateTouchThread = (iState == 1); // 0: down 1:up
if (!bIRQrunning)
touchThread = new Thread(TouchThread);
touchThread.Priority = ThreadPriority.AboveNormal;
touchThread.Start();
private void InitTouch(TouchConfiguration touchConfig)
spi = new SPI(new SPI.Configuration(touchConfig.ChipSelect, false, 1, 1, false, true, 2000, touchConfig.Channel));
touchIRQ = new InterruptPort(touchConfig.TouchIRQ, false, Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeBoth);
touchIRQ.OnInterrupt += new NativeEventHandler(touch_OnInterrupt);
terminateTouchThread = false;
public void SetPowerMode(PowerMode powerMode)
if (this.powerMode != powerMode)
// save power mode
this.powerMode = powerMode;
// set new power mode
switch (this.powerMode)
case PowerMode.Normal:
break;
case PowerMode.Sleep:
this.WriteRegister(0x10, 0x1691);
break;
case PowerMode.StandBy:
this.WriteRegister(0x10, 0x1692);
break;
case PowerMode.DeepStandBy:
this.WriteRegister(0x10, 0x1694);
break;
public void SetDisplayMode(DisplayMode displayMode)
if (this.displayMode != displayMode)
// save display mode
this.displayMode = displayMode;
// set new display mode
switch (this.displayMode)
case DisplayMode.Normal:
this.SetBackLightLevel(100);
break;
case DisplayMode.Dim:
this.SetBackLightLevel(5);
break;
case DisplayMode.Off:
this.SetBackLightLevel(0);
this.WriteRegister(0x07, 0x0131);
break;
public void SetBackLightLevel(int backlightLevel)
// check for valid parameters
if (backlightLevel < 0 || backlightLevel > 100)
throw new ArgumentException();
if (this.backlightLevel != backlightLevel)
// save back light level
this.backlightLevel = backlightLevel;
// set new back light level
if (this.backlightLevel == 0)
this.lcdBackLight.Set(false);
else if (this.backlightLevel == 100)
this.lcdBackLight.Set(true);
const int PERIOD = 10000;
int highTime = PERIOD * this.backlightLevel / 100;
this.lcdBackLight.Set(true, new uint[2] { (uint)highTime, (uint)(PERIOD - highTime) }, 0, 2, true);
#endregion
#region Drawing Methods
public void ClearScreen()
this.FillRectangle(0, 0, this.ScreenWidth, this.ScreenHeight, FEZ_Components.FEZTouch.Color.Black); // fill screen with black
public Color ColorFromRGB(byte red, byte green, byte blue)
return (Color)((red >> 3) | ((green & 0xFC) << 3) | ((blue & 0xF8) << 8));
private void SetPixelAddress(int x, int y)
this.WriteRegister(0x20, (ushort)x);
this.WriteRegister(0x21, (ushort)y);
private void SetDrawingWindow(int x, int y, int width, int height)
// pixel address
this.SetPixelAddress(x, y);
// window
this.WriteRegister(0x50, (ushort)x);
this.WriteRegister(0x52, (ushort)y);
this.WriteRegister(0x51, (ushort)(x + width - 1));
this.WriteRegister(0x53, (ushort)(y + height - 1));
public void SetPixel(int x, int y, Color color)
if (x < 0 || y < 0 || x >= this.ScreenWidth || y >= this.ScreenHeight)
throw new ArgumentException("SetPixel: Invalid parameter values.");
this.buffer[0] = (byte)((int)color >> 8);
this.buffer[1] = (byte)(color);
this.SetDrawingWindow(x, y, 1, 1);
this.SetRegister(REGISTER_WRITE_GRAM);
this.parallelPort.Write(this.buffer, 0, 2);
public void DrawLine(int xStart, int yStart, int xEnd, int yEnd, Color color)
if (xStart < 0 || yStart < 0 || xStart >= this.ScreenWidth || yStart >= this.ScreenHeight)
throw new ArgumentException("DrawLine: Invalid start position values.");
if (xEnd < 0 || yEnd < 0 || xEnd >= this.ScreenWidth || yEnd >= this.ScreenHeight)
throw new ArgumentException("DrawLine: Invalid end position values.");
// translate coordinates based on display orientation
int x0 = 0;
int y0 = 0;
int x1 = 0;
int y1 = 0;
x0 = xStart;
y0 = yStart;
x1 = xEnd;
y1 = yEnd;
break;
x0 = SCREEN_WIDTH - yStart - 1;
y0 = xStart;
x1 = SCREEN_WIDTH - yEnd - 1;
y1 = xEnd;
break;
x0 = yStart;
y0 = SCREEN_HEIGHT - xStart - 1;
x1 = yEnd;
y1 = SCREEN_HEIGHT - xEnd - 1;
break;
int dy = y1 - y0;
int dx = x1 - x0;
float m = 0;
int b = 0;
if (dx != 0)
m = ((float)(dy)) / (dx);
b = y0 - (int)(m * x0);
if (global::System.Math.Abs(dx) >= global::System.Math.Abs(dy))
if (x0 > x1)
this.Swap(ref x0, ref x1);
this.Swap(ref y0, ref y1);
while (x0 <= x1)
this.SetDrawingWindow(x0, y0, 1, 1);
x0++;
if (x0 <= x1)
y0 = (int)(m * x0) + b;
if (y0 > y1)
while (y0 <= y1)
y0++;
if (y0 <= y1)
if (dx != 0)
x0 = (int)((float)(y0 - b) / m);
public void FillRectangle(int xPos, int yPos, int rectWidth, int rectHeight, Color color)
// validate parameter values
if (xPos < 0 || yPos < 0 || (xPos + rectWidth) > this.ScreenWidth || (yPos + rectHeight) > this.ScreenHeight)
throw new ArgumentException("FillRectangle: Invalid parameter values.");
int x = 0;
int y = 0;
int width = 0;
int height = 0;
x = xPos;
y = yPos;
width = rectWidth;
height = rectHeight;
break;
x = SCREEN_WIDTH - yPos - rectHeight;
y = xPos;
width = rectHeight;
height = rectWidth;
break;
x = yPos;
y = SCREEN_HEIGHT - xPos - rectWidth;
width = rectHeight;
height = rectWidth;
break;
int pixelCount = width * height;
int bufferPixels = this.buffer.Length / 2; // every pixel is 2 bytes
byte h = (byte)((int)color >> 8);
byte l = (byte)(color);
// fill buffer
for (int i = 0; i < this.buffer.Length; i = i + 2)
this.buffer[i] = h;
this.buffer[i + 1] = l;
this.SetDrawingWindow(x, y, width, height);
int loops = pixelCount / bufferPixels;
for (int i = 0; i < loops; i++)
this.parallelPort.Write(this.buffer, 0, this.buffer.Length);
int pixelsLeft = pixelCount % bufferPixels;
if (pixelsLeft > 0)
this.parallelPort.Write(this.buffer, 0, pixelsLeft * 2);
public void DrawImage(int xPos, int yPos, Image image)
if (xPos < 0 || yPos < 0 || (xPos + image.Width) > this.ScreenWidth || (yPos + image.Height) > this.ScreenHeight)
throw new ArgumentException("DrawImage: Invalid parameter values.");
int x = 0;
int y = 0;
int width = 0;
int height = 0;
x = xPos;
y = yPos;
width = image.Width;
height = image.Height;
break;
x = SCREEN_WIDTH - yPos - image.Height;
y = xPos;
width = image.Height;
height = image.Width;
break;
x = yPos;
y = SCREEN_HEIGHT - xPos - image.Width;
break;
this.parallelPort.Write(image.ImageBytes, Image.IMG_PIXELS_INDEX, image.ImageBytes.Length - Image.IMG_PIXELS_INDEX);
public void DrawString(int xPos, int yPos, string text, Color fgColor, Color bgColor, Font font)
if (xPos < 0 || yPos < 0)
throw new ArgumentException("DrawString: Screen position (x,y) is invalid.");
if ((xPos + font.GetTextWidth(text)) > this.ScreenWidth || (yPos + font.Height) > this.ScreenHeight)
throw new ArgumentException("DrawString: Text string is too wide or too high to fit on the screen.");
int x = 0;
int y = 0;
int width = 0;
int height = 0;
x = xPos;
y = yPos;
break;
x = SCREEN_WIDTH - yPos - font.Height;
y = xPos;
break;
x = yPos;
y = SCREEN_HEIGHT - xPos - font.AverageWidth;
break;
// split colors into bytes
byte fgColorHigh = (byte)((int)fgColor >> 8);
byte fgColorLow = (byte)(fgColor);
byte bgColorHigh = (byte)((int)bgColor >> 8);
byte bgColorLow = (byte)(bgColor);
// draw each character
char currentChar = ' ';
CharInfo charInfo = null;
int bytesInBuffer = 0;
for (int charIndex = 0; charIndex < text.Length; charIndex++)
// get character
currentChar = text[charIndex];
// get character info
charInfo = font[currentChar];
// translate width and height based on display orientation
width = charInfo.Width;
height = charInfo.Height;
break;
width = charInfo.Height;
height = charInfo.Width;
break;
break;
// get character pixels
bytesInBuffer = font.FillBitmapBuffer(charInfo, this.buffer, fgColorLow, fgColorHigh, bgColorLow, bgColorHigh);
// output character pixels
this.parallelPort.Write(this.buffer, 0, bytesInBuffer);
// update x position
x += width;
break;
y += height;
break;
y -= height;
break;
#endregion
#region Interface Methods
private void Swap(ref int a1, ref int a2)
int temp = a1;
a1 = a2;
a2 = temp;
private void SetRegister(byte register)
this.lcdRegSelect.Write(false);
this.regBuffer[0] = 0;
this.regBuffer[1] = register;
this.parallelPort.Write(this.regBuffer, 0, 2);
this.lcdRegSelect.Write(true);
private void WriteRegister(byte register, ushort value)
this.SetRegister(register);
this.regBuffer[0] = (byte)(value >> 8);
this.regBuffer[1] = (byte)(value);
this.parallelPort.Write(regBuffer, 0, 2);
#endregion
#region Touch Thread & Methods
private void TouchThread()
if (bIRQrunning) return;
bIRQrunning = true;
int x = 0;
int y = 0;
getTouchCoord(ref x, ref y);
FireTouchDownEvent(x, y);
while (terminateTouchThread == false)
Thread.Sleep(TOUCH_SAMPLING_TIME);
this.FireTouchMoveEvent(x, y);
this.FireTouchUpEvent(x, y);
bIRQrunning = false;
static byte[] writeBuffer = new byte[] { 0, 0, 0, 0 };
static byte[] readBuffer = new byte[2];
private const int TOUCHXMAX = 3385;
private const int TOUCHXMIN = 620;
private const int TOUCHYMIN = 800;
private const int TOUCHYMAX = 3500;
//private int xMin=5000;
//private int xMax = 0;
//private int yMin = 5000;
//private int yMax = 0;
private void getTouchCoord(ref int x, ref int y)
touchIRQ.OnInterrupt -= new NativeEventHandler(touch_OnInterrupt);
writeBuffer[0] = 0x90;
spi.WriteRead(writeBuffer, readBuffer, 1);
y = readBuffer[0];
y <<= 8;
y |= readBuffer[1];
y >>= 3;
writeBuffer[0] = 0xD0;
x = readBuffer[0];
x <<= 8;
x |= readBuffer[1];
x >>= 3;
//if (x != 0 && x != 4095 && y != 0 && y != 4095) //get extrema
// if (x < xMin) { xMin = x; Debug.Print("xmin=" + xMin.ToString()); }
// if (x > xMax) { xMax = x; Debug.Print("xmax=" + xMax.ToString()); }
// if (y < yMin) { yMin = y; Debug.Print("ymin=" + yMin.ToString()); }
// if (y > yMax) { yMax = y; Debug.Print("ymax=" + yMax.ToString()); }
// calibrate
x = (TOUCHXMAX - x) * (SCREEN_WIDTH - 1) / (TOUCHXMAX - TOUCHXMIN);
y = (TOUCHYMAX - y) * (SCREEN_HEIGHT - 1) / (TOUCHYMAX - TOUCHYMIN);
y = y > SCREEN_HEIGHT ? SCREEN_HEIGHT : y; y = y < 0 ? 0 : y;
x = x > SCREEN_WIDTH ? SCREEN_WIDTH : x; x = x < 0 ? 0 : x;
private void FireTouchDownEvent(int xPos, int yPos)
if (this.TouchDownEvent != null)
int x = 0;
int y = 0;
x = xPos;
y = yPos;
break;
x = yPos;
y = SCREEN_WIDTH - xPos - 1;
break;
x = SCREEN_HEIGHT - yPos - 1;
y = xPos;
break;
// fire the event
this.TouchDownEvent(x, y);
private void FireTouchMoveEvent(int xPos, int yPos)
if (this.TouchMoveEvent != null)
int x = 0;
int y = 0;
x = xPos;
y = yPos;
break;
x = yPos;
break;
y = xPos;
break;
// fire the event
this.TouchMoveEvent(x, y);
private void FireTouchUpEvent(int xPos, int yPos)
if (this.TouchUpEvent != null)
int x = 0;
int y = 0;
x = xPos;
y = yPos;
break;
x = yPos;
break;
y = xPos;
break;
// fire the event
this.TouchUpEvent(x, y);
#endregion
#region Font Classes
public class Font
// CONSTRUCTORS
protected Font()
// this constructor is not for external access
this.avgWidth = 0;
this.maxWidth = 0;
this.height = 0;
this.startChar = '\x00';
this.endChar = '\x00';
this.charDescriptors = null;
this.charBitmaps = null;
// PROPERTIES
public ushort AverageWidth
get { return this.avgWidth; }
public ushort MaxWidth
get { return this.maxWidth; }
public ushort Height
get { return this.height; }
public CharInfo this[char newChar]
get
if (newChar < this.startChar || newChar > this.endChar)
throw new ArgumentException("Font class: character not found.");
ushort bitMask = 0x7FFF;
int descriptorIndex = (newChar - this.startChar) * constSizeOfCharDescriptor;
ushort charWidth = (ushort)(this.charDescriptors[descriptorIndex] & bitMask);
ushort charHeight = (ushort)(this.charDescriptors[descriptorIndex + 1] & bitMask);
ushort bitmapStartIndex = (ushort)(this.charDescriptors[descriptorIndex + 2] & bitMask);
ushort bitmapLength = (ushort)(this.charDescriptors[descriptorIndex + 3] & bitMask);
return new CharInfo(newChar, charWidth, charHeight, bitmapStartIndex, bitmapLength);
// METHODS
public int GetTextWidth(string text)
int totalPixels = 0;
foreach (char character in text)
totalPixels += this[character].Width;
return totalPixels;
public int FillBitmapBuffer(CharInfo charInfo, byte[] buffer, byte fgColorLow, byte fgColorHigh, byte bgColorLow, byte bgColorHigh)
// check the buffer size
int charBytesReq = charInfo.Width * charInfo.Height * 2;
int totalBytesReq = charInfo.Width * this.height * 2;
if (buffer.Length < totalBytesReq)
throw new ArgumentException("Buffer length is not large enough for this character.");
// fill the buffer
ushort bitmapValue = 0;
int bufferIndex = 0;
ushort bitmapIndex = charInfo.BitmapStartIndex;
for (int i = 0; i < charInfo.BitmapLength; i++, bitmapIndex++)
bitmapValue = (ushort)this.charBitmaps[bitmapIndex];
for (ushort bitMask = (ushort)0x0001; bitMask < (ushort)0x8000; )
// add pixel color
if ((bitmapValue & bitMask) == bitMask)
// add foreground color
buffer[bufferIndex] = fgColorHigh;
buffer[bufferIndex + 1] = fgColorLow;
// add background color
buffer[bufferIndex] = bgColorHigh;
buffer[bufferIndex + 1] = bgColorLow;
// adjust bitMask, increment pixelsRead, and increment bufferIndex
bitMask = (ushort)(bitMask << 1);
bufferIndex += 2;
// check if we are done
if (bufferIndex >= charBytesReq)
break;
// add blank rows
while (bufferIndex < totalBytesReq)
bufferIndex += 2;
// return num bytes in buffer
return bufferIndex;
// MEMBER FIELDS
protected ushort avgWidth;
protected ushort maxWidth;
protected ushort height;
protected char startChar;
protected char endChar;
protected string charDescriptors;
protected string charBitmaps;
protected const int constSizeOfCharDescriptor = 4; // number of chars in each descriptor
public class CharInfo
// CONSTRUCTORS
public CharInfo(char character, ushort charWidth, ushort charHeight, ushort bitmapStartIndex, ushort bitmapLength)
this.character = character;
this.charWidth = charWidth;
this.charHeight = charHeight;
this.bitmapStartIndex = bitmapStartIndex;
this.bitmapLength = bitmapLength;
// PROPERTIES
public char Character
get { return this.character; }
public ushort Width
get { return this.charWidth; }
get { return this.charHeight; }
public ushort BitmapStartIndex
get { return this.bitmapStartIndex; }
public ushort BitmapLength
get { return this.bitmapLength; }
// MEMBER FIELDS
private char character;
private ushort charWidth;
private ushort charHeight;
private ushort bitmapStartIndex;
private ushort bitmapLength;
#endregion
#region Image Class
public class Image
// CONSTRUCTORS
public Image(byte[] imgBytes)
if (Utility.ExtractValueFromArray(imgBytes, 0, 4) != SIGNATURE)
throw new ArgumentException("Image Class: Signature bytes not found.");
int width = (int)Utility.ExtractValueFromArray(imgBytes, 4, 2);
int height = (int)Utility.ExtractValueFromArray(imgBytes, 6, 2);
if (width * height * 2 + 8 != imgBytes.Length)
throw new ArgumentException("Image class: Width and height do not match size of byte array.");
this.ImageBytes = imgBytes;
this.Width = width;
this.Height = height;
// PROPERTIES
public readonly int Width;
public readonly int Height;
public const uint SIGNATURE = 0x354A82B8;
public const int IMG_PIXELS_INDEX = 8;
public byte[] ImageBytes;
#endregion
#region LCD Configuration Class
public class LCDConfiguration
// CONSTRUCTORS
public LCDConfiguration(FEZ_Pin.Digital reset,
FEZ_Pin.Digital chipSelect,
FEZ_Pin.Digital RS,
FEZ_Pin.Digital lcdBackLight,
FEZ_Pin.Digital[] dataPins,
FEZ_Pin.Digital writePin,
FEZ_Pin.Digital readPin,
Orientation lcdOrientation)
this.DataPins = new Cpu.Pin[8];
for (int i = 0; i < 8; i++)
this.DataPins[i] = (Cpu.Pin)dataPins[i];
this.WritePin = (Cpu.Pin)writePin;
this.ReadPin = (Cpu.Pin)readPin;
this.ChipSelect = (Cpu.Pin)chipSelect;
this.Reset = (Cpu.Pin)reset;
this.RS = (Cpu.Pin)RS;
this.BackLight = (Cpu.Pin)lcdBackLight;
this.LCDOrientation = lcdOrientation;
// PROPERTIES
public Cpu.Pin[] DataPins;
public Cpu.Pin WritePin;
public Cpu.Pin ReadPin;
public Cpu.Pin ChipSelect;
public Cpu.Pin Reset;
public Cpu.Pin RS;
public Cpu.Pin BackLight;
public Orientation LCDOrientation;
#endregion
#region Touch Configuration Class
public class TouchConfiguration
public SPI.SPI_module Channel;
public Cpu.Pin TouchIRQ;
public TouchConfiguration(SPI.SPI_module channel, FEZ_Pin.Digital chipSelect, FEZ_Pin.Digital touchIRQ)
this.Channel = channel;
this.TouchIRQ = (Cpu.Pin)touchIRQ;
#endregion
#region Member Fields
// constants
private const int SCREEN_WIDTH = 240;
private const int SCREEN_HEIGHT = 320;
private const int BUFFER_SIZE = 2024;
private const byte REGISTER_WRITE_GRAM = 0x22;
private const int TOUCH_SAMPLING_TIME = 10;
private bool disposed = false;
private byte[] buffer = new byte[BUFFER_SIZE];
private byte[] regBuffer = new byte[2];
// lcd configuration
private ParallelPort parallelPort;
private OutputPort lcdReset;
private OutputPort lcdChipSelect;
private OutputPort lcdRegSelect;
private OutputCompare lcdBackLight;
private Orientation lcdOrientation;
// touch configuration
private static SPI spi;
public static InterruptPort touchIRQ;
private static bool terminateTouchThread;
private static bool bIRQrunning = false;
private Thread touchThread;
// display mode
private DisplayMode displayMode;
private int backlightLevel;
#endregion
