Guys,
does anyone have an example on how to establish serial communication between FEZ boards using CTS/RTS ?
Guys,
I can give you few hints:
There is a UART(COM) port on each FEZ Board that supports hardware handshaking.
In the code add this
_port.Handshake = Handshake.RequestToSend;
If you are connecting two FEZ Boards then connect:
RX <–>TX
TX <–>RX
CTS<–>RTS
RTS<–>CTS
Note: I assume that you are making direct connection with the TTL levels (Not RS232 levels).
Thanks Joe,
I suppose this line has to be on both FEZ boards?
And all the magic will happen behind the scenes, right?
Indeed, straight pin to pin connections.
