In case anyone is interested and a lot of you might know this but Gravicode has an effort to port Gadgeteer to TinyCLR https://github.com/Gravicode/GadgeteerToTinyCLR
I used the Button class but had to make some minor changes to it because of the Edge problem.
//using GT = Gadgeteer;
//using GTI = Gadgeteer.SocketInterfaces;
//using GTM = Gadgeteer.Modules;
//namespace Gadgeteer.Modules.GHIElectronics
namespace ButtonExp
A Button module for .NET Gadgeteer
public class Button
private GpioPin input;
private GpioPin led;
private LedMode currentMode;
private ButtonEventHandler onButtonEvent;
/// <summary>Represents the delegate that is used to handle the <see cref="ButtonReleased" /> and <see cref="ButtonPressed" /> events.</summary>
/// <param name="sender">The <see cref="Button" /> object that raised the event.</param>
/// <param name="state">The state of the Button</param>
public delegate void ButtonEventHandler(Button sender, ButtonState state);
/// <summary>Raised when the button is released.</summary>
public event ButtonEventHandler ButtonReleased;
/// <summary>Raised when the button is pressed.</summary>
public event ButtonEventHandler ButtonPressed;
/// <summary>Whether or not the button is pressed.</summary>
public bool Pressed
get
return !(this.input.Read() == GpioPinValue.High);
/// <summary>Whether or not the LED is currently on or off.</summary>
public bool IsLedOn
get
return this.led.Read() == GpioPinValue.High;
/// <summary>Gets or sets the LED's current mode of operation.</summary>
public LedMode Mode
get
return this.currentMode;
set
this.currentMode = value;
if (this.currentMode == LedMode.On || (this.currentMode == LedMode.OnWhilePressed && this.Pressed) || (this.currentMode == LedMode.OnWhileReleased && !this.Pressed))
this.TurnLedOn();
else if (this.currentMode == LedMode.Off || (this.currentMode == LedMode.OnWhileReleased && this.Pressed) || (this.currentMode == LedMode.OnWhilePressed && !this.Pressed))
this.TurnLedOff();
/// <summary>The state of the button.</summary>
public enum ButtonState
/// <summary>The button is pressed.</summary>
Pressed = 0,
/// <summary>The button is released.</summary>
Released = 1
/// <summary>The various modes a LED can be set to.</summary>
public enum LedMode
/// <summary>The LED is on regardless of the button state.</summary>
On,
/// <summary>The LED is off regardless of the button state.</summary>
Off,
/// <summary>The LED changes state whenever the button is pressed.</summary>
ToggleWhenPressed,
/// <summary>The LED changes state whenever the button is released.</summary>
ToggleWhenReleased,
/// <summary>The LED is on while the button is pressed.</summary>
OnWhilePressed,
/// <summary>The LED is on except when the button is pressed.</summary>
OnWhileReleased
/// <summary>Constructs a new instance.</summary>
/// <param name="DigitalPin3">The mainboard pin that has digital pin.</param>
/// <param name="DigitalPin4">The mainboard pin that has digital pin.</param>
public Button(int DigitalPin3, int DigitalPin4)
//Socket socket = Socket.GetSocket(socketNumber, true, this, null);
//socket.EnsureTypeIsSupported(new char[] { 'X', 'Y' }, this);
this.currentMode = LedMode.Off;
var controller = GpioController.GetDefault();
this.led = controller.OpenPin(DigitalPin4);
this.led.SetDriveMode(GpioPinDriveMode.Output);
this.input = controller.OpenPin(DigitalPin3);//GTI.InterruptInputFactory.Create(socket, GT.Socket.Pin.Three, GTI.GlitchFilterMode.On, GTI.ResistorMode.PullUp, GTI.InterruptMode.RisingAndFallingEdge, this);
if (input.IsDriveModeSupported(GpioPinDriveMode.InputPullUp))
input.SetDriveMode(GpioPinDriveMode.InputPullUp);
input.SetDriveMode(GpioPinDriveMode.Input);
//this.input.Interrupt += this.OnInterrupt;
input.ValueChanged += Input_ValueChanged; ;
// Dan Miller 12/3/2017: Modified the event methode because pin edge is not reporting correctly with TinyCLR v0.6.0.
//private void Input_ValueChanged(object sender, GpioPinValueChangedEventArgs e)
private void Input_ValueChanged(GpioPin sender, GpioPinValueChangedEventArgs e)
//var state = e.Edge == GpioPinEdge.FallingEdge ? ButtonState.Released : ButtonState.Pressed;
var state = sender.Read() == GpioPinValue.High ? ButtonState.Released : ButtonState.Pressed;
switch (state)
case ButtonState.Released:
if (this.Mode == LedMode.OnWhilePressed)
this.TurnLedOff();
else if (this.Mode == LedMode.OnWhileReleased)
this.TurnLedOn();
else if (this.Mode == LedMode.ToggleWhenReleased)
this.ToggleLED();
break;
case ButtonState.Pressed:
this.TurnLedOn();
this.TurnLedOff();
else if (this.Mode == LedMode.ToggleWhenPressed)
this.ToggleLED();
break;
this.OnButtonEvent(this, state);
/// <summary>Turns on the LED.</summary>
public void TurnLedOn()
this.led.Write(GpioPinValue.High);
/// <summary>Turns off the LED.</summary>
public void TurnLedOff()
this.led.Write(GpioPinValue.Low);
/// <summary>Turns the LED off if it is on and on if it is off.</summary>
public void ToggleLED()
if (this.IsLedOn)
this.TurnLedOff();
this.TurnLedOn();
private void OnInterrupt(GTI.InterruptInput input, bool value)
var state = value ? ButtonState.Released : ButtonState.Pressed;
switch (state)
this.TurnLedOff();
this.TurnLedOn();
this.ToggleLED();
break;
this.TurnLedOn();
this.TurnLedOff();
this.ToggleLED();
break;
private void OnButtonEvent(Button sender, ButtonState state)
if (this.onButtonEvent == null)
this.onButtonEvent = this.OnButtonEvent;
switch (state)
if (ButtonReleased != null)
this.ButtonReleased(sender, state); break;
if (ButtonPressed != null)
this.ButtonPressed(sender, state); break;
if (Program.CheckAndInvoke(state == ButtonState.Released ? this.ButtonReleased : this.ButtonPressed, this.onButtonEvent, sender, state))
switch (state)
case ButtonState.Released: this.ButtonReleased(sender, state); break;
case ButtonState.Pressed: this.ButtonPressed(sender, state); break;
