Hello,
I currently own a FEZ Spider kit and I have a general question about its processing power.
In fact, I would like to build a video recorder with the following modules:
FEZ Spider Mainboard, Camera Module (or usb cam), SD card module and power module.
Do you think it is possible to have at least the following performance with the above configuration:
*Recording of 5-10 frames per second.
*Resolution of 320x240 (or less if needed)
*Compression to JPEG or PNG or MPEG ?
*Possibly I would like to add some text overlay on the image (ex: timestamp)
*Saving to SD card. (in the compressed format)
Do you think the FEZ Spider is an appropriate device to perform this task ?
If not, do you know another kit which could be able to do it ? (Ex: FEZ Hydra or ChipworkX or something else?)
