FEZ Spider : DNS problem when using IP, Gateway and DNS assigned by DHCP
Hi all,
until today I used my FEZ Spider without problems with static IP amd static DNS.
Today I need to switch to DHCP and dynamucally assigned DNS.
The board receives IP, Gateway and DNS but …
Now the problem…
To get time from the network I use a simple :
IPHostEntry hostEntry = Dns.GetHostEntry(“time.nist.gov”);
This method hangs and time out !!
It works pretty well in the static IP configuration !
Any info about this issue ?
Thanks,
Paolo.
@ ppatierno - Have you tried reflashing the firmware? Can you post a small program that reproduces the issue?
