I tried to connect the FEZ-relay to any of the 3.3V IO on the emx development board. However I cannot get the relays to trigger. I had to disconnect the connector as the emx development board does not have the right sockets. What signal has to be connected to each of the wires? red/black/green?
Do i need to use the Fez_component_relay drivers? or can i just switch an EMX OutputPort?
Thanks!
The relay cable consists of 3 items:
+5v
SIGNAL
GND
A high signal will switch the relay on, a low signal will turn it off.
You can just set the state to true or false.
Color codes of the cables are:
Red: +5v
Green: SIGNAL
Black: GND
Where the connections are so that the signal is between the +5v and GND.
Thanks,
I connected it with help of your pointers! I can now correctly trigger the relays!
Is there a schema available for the Fez-relays. I mean what components are used. So maybe I can have them custom made. For when they might not be available for sale anymore.
Thanks again.
You’re welcome. That’s what we are here for ;D
There are, as far as I know, no schemes of the components online. However, it’s not hard to make.
You will need a relay (of course ;D )
GHI uses this one: (any 5v relay (or more if you like) will work. It depends on your needs)
http://components.omron.eu/en/products/catalogue/relays/pcb_power_relays/up_to_16a/g5la/default.html
You will then need a transistor (for “switching” the relay with a IO - I like to have things safe
), some diodes (protecting your board) and some resistors.
If you need some inspiration or some more understanding sparkfun has a relay PCB
http://www.sparkfun.com/products/9096
Good luck
