FEZ Raptor + USB Client DP
Hello,
I’m trying to connect to my FEZ Raptor board using a USB Client DP Module, but I cannot get it to communicate.
I have connected them as showed in the first picture.
As soon as I connect the USB cable, it appears amont the USB devices, but with a warning icon (second picture).
If I delete the driver, scan for hardware changes, I get it connected properly (third picture).
If I then try to execute the FEZ Config (fourth picture) and I run the Check for device update, I see that the TinyBooter is not up to date.
I tried to run the Firmware Update. It runs without problems during the Deploying of the firmware (fifth picture), but then the USB interface disconnects and reconnects again with an error, and the Firmware Update stops with an error (sixth picture).
The device Properties say “Impossible to start the device (Code 10)”.
If I then try to run even very simply program, I always get this failure:
Attaching to device…
Waiting for device to initialize…
The debugging target and the debugger engine failed to initialize because of unspecified device errors.
The debugger engine thread has terminated unexpectedly with error ‘Could not reconnect to the debugging target after rebooting it.’.
Any idea?
Thank you for your help,
Gianluca
Did you Look in the G400 SoM User manual how to Update the boot loader with SAM-BA?
