FEZ Raptor: missing a using directive or an assembly reference?
Hardware: FEZ Raptor
SDK: 4.3
I am attempting to use Ascended Temperature MCP9701(https://www.ghielectronics.com/community/codeshare/entry/81) in my project, but I am running into these two errors:
and
tempSensor.cs code:
//           Ascended International
//             Copyright (c) 2010
//            All Rights Reserved
//    * DO NOT REMOVE THIS HEADER. DO NOT MODIFY THIS HEADER *
 * You may use this class for non-commercial purposes. If you wish to use this    *
 * software for a commercial purpose please contact Ascended International at:    *
 * mark@ ascended.com.au                                                           *
 * When using this free class, no warranty express or implied is offered.         *
 * In no event shall Ascended International, any of it's employees or shareholders*
 * be held liable for any direct, indirect, special, exemplary, incidental or     *
 * consequential damages however caused.                                          *
 * If you modify this class, please add your name and the date below as a         *
 * contributor, without removing this notice or modifying it in any way, shape    *
 * or form.        *
 #if NETDUINO
using SecretLabs.NETMF.Hardware;
 #else
 #endif
namespace Ascended.SPOT.Sensors.Temperature
    public interface ITemperatureSensor : IDisposable
        float GetTemperatureInC();
        float GetTemperatureInF();
        int MaximumTemperatureCapability { get; }
        int MinimumTemperatureCapability { get; }
    public class MCP9701 : ITemperatureSensor
 #if NETDUINO
        protected AnalogInput sensor;
 #else
        protected AnalogIn sensor;
 #endif
        /// <summary>
        /// Create a new base instance of the temperature sensor.
        /// </summary>
        /// <param name="pin">Pin the sensor's vout is connected to.
        public MCP9701(Cpu.Pin pin)
            // http://www.microchip.com/wwwproducts/Devices.aspx?dDocName=en022289
            MaximumTemperatureCapability = 125;
            MinimumTemperatureCapability = -40;
            RequiredVoltage = 2.7f;
 #if NETDUINO
            sensor = new AnalogInput(pin);
            sensor.SetRange(0, 3300);
 #else
            sensor = new AnalogIn((AnalogIn.Pin)pin);
            sensor.SetLinearScale(0, 3300);
 #endif
        public float GetTemperatureInC()
            // gain = 19.53 mV/Deg C
            int mv = sensor.Read() - 400; // 400 = 0c
            return mv / 19.53f;
        public float GetTemperatureInF()
            return GetTemperatureInC() * 9 / 5 + 32;
        public int MaximumTemperatureCapability { get; protected set; }
        public int MinimumTemperatureCapability { get; protected set; }
        public float RequiredVoltage { get; protected set; }
        public void Dispose()
            sensor.Dispose();
            sensor = null;
Program.cs code:
using System.Collections;
using System.Text;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
using Gadgeteer.SocketInterfaces;
using Ascended.SPOT.Sensors.Temperature;
namespace iog
    public partial class Program
            Mainboard.SetDebugLED(true);
            this.usbSerial.Configure(9600, SerialParity.None, SerialStopBits.One, 8, HardwareFlowControl.NotRequired);
            this.usbSerial.Port.NewLine = "\r";
            this.usbSerial.Port.LineReceived += this.Port_lineReceived;
        private void Port_lineReceived(Serial sender, string line)
            /*Demo usbSerial communication to test I/O data which works :-)*/
            Debug.Print(line);
            if (line == "Off") Mainboard.SetDebugLED(false);
            else if (line == "On") Mainboard.SetDebugLED(true);
            /*End usbSerial Demo*/
            /*Now get MCP9701 value and send the value  usbSerial*/
            using (ITemperatureSensor sensor = new MCP9701((Cpu.Pin)AnalogIn.Pin.Ain0))
                    Debug.Print("Temperature: " + sensor.GetTemperatureInC() + "c");
                    Thread.Sleep(1000);
Errors:
[quote]Error 1 The type or namespace name ‘NETMF’ does not exist in the namespace ‘GHIElectronics’ (are you missing an assembly reference?)
C:\Users\Rich\documents\visual studio 2012\Projects\iog\iog\tempSensor.cs 28 22 iog
Error 2 The type or namespace name ‘NETMF’ does not exist in the namespace ‘GHIElectronics’ (are you missing an assembly reference?)
C:\Users\Rich\documents\visual studio 2012\Projects\iog\iog\tempSensor.cs 29 22 iog
Error 3 The type or namespace name ‘AnalogIn’ could not be found (are you missing a using directive or an assembly reference?)
C:\Users\Rich\documents\visual studio 2012\Projects\iog\iog\tempSensor.cs 48 19 iog
Error 4 The type or namespace name ‘AnalogIn’ could not be found (are you missing a using directive or an assembly reference?)
C:\Users\Rich\documents\visual studio 2012\Projects\iog\iog\tempSensor.cs 66 26 iog
Error 5 The type or namespace name ‘AnalogIn’ could not be found (are you missing a using directive or an assembly reference?)
C:\Users\Rich\documents\visual studio 2012\Projects\iog\iog\tempSensor.cs 66 36 iog
Error 6 The type or namespace name ‘NETMF’ does not exist in the namespace ‘GHIElectronics’ (are you missing an assembly reference?)
C:\Users\Rich\documents\visual studio 2012\Projects\iog\iog\Program.cs 19 22 iog
Error 7 The name ‘AnalogIn’ does not exist in the current context C:\Users\Rich\documents\visual studio 2012\Projects\iog\iog\Program.cs 47 69 iog[/quote]
I attached an image of my included References.
Namespaces changed between versions. I would remove the namespace in question and resolve “unknown” classes by looking them in the latest GHI SDK.
Does removing unused references or like “using …” statements make any performance improvements? Why not have ALL of the references at once?
The only negative of having unused assemblies/references included is slightly slower compile time… and maybe any other programmer looking at your code wondering “why did he include that?”
@ Architec
I read through the 4.3 API and I was needing to use AnalogInput not Analogin. I changed some of the code in the tempSensor.cs class in an attempt to get the class to work with 4.3. I now have two more errors.
I know SetLinearScale isn’t a method and I can’t use Scale because Scale is a non-invocable member and cannot be used as a method. As far as the second error, I have no idea what that means or what a ‘cast’ has to do with this. I still have a lot to learn with C#.
[quote]The new errors that I am receiving are:
Error 1 ‘Microsoft.SPOT.Hardware.AnalogInput’ does not contain a definition for ‘SetLinearScale’ and no extension method ‘SetLinearScale’ accepting a first argument of type ‘Microsoft.SPOT.Hardware.AnalogInput’ could be found (are you missing a using directive or an assembly reference?) C:\Users\Rich\Documents\Visual Studio 2012\Projects\iog\iog\tempSensor.cs 55 20 iog
Error 2 Cannot implicitly convert type ‘double’ to ‘int’. An explicit conversion exists (are you missing a cast?) C:\Users\Rich\Documents\Visual Studio 2012\Projects\iog\iog\tempSensor.cs 61 22 iog
[/quote]
tempSensor.cs:
 * or form.        *
        /// <summary>
        /// </summary>
        public MCP9701(Cpu.AnalogChannel pin)
        //public MCP9701(Cpu.Pin pin)
            //sensor = new AnalogInput((AnalogInput.Pin)pin);
            //sensor.Scale(0, 3300);
            return mv / 19.53f;
            sensor.Dispose();
            sensor = null;
I researched a bit to find out what a ‘cast’ is. To my understanding a cast has to be used to convert a double to int. So I did:
That fix the casting issue.  One more error that I need to fix:
[quote]Error	1	'Microsoft.SPOT.Hardware.AnalogInput' does not contain a definition for 'SetLinearScale' and no extension method 'SetLinearScale' accepting a first argument of type 'Microsoft.SPOT.Hardware.AnalogInput' could be found (are you missing a using directive or an assembly reference?)	C:\Users\Rich\Documents\Visual Studio 2012\Projects\iog\iog\tempSensor.cs	56	20	iog[/quote]
That error points to:
```cs]sensor.SetLinearScale(0, 3300);[/code
I am still stuck on that and I have no idea what to do to fix it :/
Set Linear Scale simply “converted” an integer number (the return of the RAW ADC value) into a number that has a different lower and upper bound. In this case it was scaling the (most likely 10-bit) number instead of going from 0 to 1023 (10 bits - may be different depending on your hardware) to run from 0 to 3300. You can do this in maths yourself.
Here’s an old post from @ Godefroi with a simple maths example https://www.ghielectronics.com/community/forum/topic?id=7832 and an alternative to scaling (since Read() already is a 0 to 1 scaled output)
