Hi all,
I know it is not possible to say it exactly because it depends on application but bellow there is an output from my application.
There is written 264msec. Does it take really so much time on a such a powerful controller which is used on G400 module?
From long term debug output (cca. 3 hours) it is possible to see that GC is executed every cca. 5 min. and what is interesting is that this time is always exactly the same - 264msec.
And second question is if this time is the same also for “release application” or it is valid only for “debug application” connected to VS(and is significantly shorted for release application)?
GC: 264msec 437280 bytes used, 66668484 bytes available
Type 0F (STRING ): 9504 bytes
Type 11 (CLASS ): 31260 bytes
Type 12 (VALUETYPE ): 3144 bytes
Type 13 (SZARRAY ): 14784 bytes
Type 03 (U1 ): 2628 bytes
Type 04 (CHAR ): 1056 bytes
Type 07 (I4 ): 1716 bytes
Type 0F (STRING ): 4968 bytes
Type 11 (CLASS ): 4416 bytes
Type 15 (FREEBLOCK ): 66668484 bytes
Type 17 (ASSEMBLY ): 36324 bytes
Type 18 (WEAKCLASS ): 48 bytes
Type 19 (REFLECTION ): 168 bytes
Type 1B (DELEGATE_HEAD ): 936 bytes
Type 1D (OBJECT_TO_EVENT ): 576 bytes
Type 1E (BINARY_BLOB_HEAD ): 325704 bytes
Type 1F (THREAD ): 3072 bytes
Type 20 (SUBTHREAD ): 384 bytes
Type 21 (STACK_FRAME ): 5928 bytes
Type 22 (TIMER_HEAD ): 288 bytes
Type 26 (WAIT_FOR_OBJECT_HEAD): 96 bytes
Type 27 (FINALIZER_HEAD ): 360 bytes
Type 31 (IO_PORT ): 324 bytes
Type 33 (I2C_XACTION ): 48 bytes
Type 36 (APPDOMAIN_ASSEMBLY ): 4260 bytes
Thanks for reply.
