Another problem has arisen, which is a new behavior, not seen before I installed the new GHI SDK. I get an error that the device cannot be found, but it is found. I have not seen this before, and it is not stopping me, but I wanted to capture the symptoms in case it is related to the SDK and not to my particular installation. My workaround is to ignore the error message and see if it works…
Here is how it shows up:
1. Rebuild solution previously running fine.
2. Start application (debug mode), error displays "There were deployment errors. Continue?"
3. Answer yes. Error list shows "37 Device not found or cannot be opened - USB:G400"
4. Immediate window show the following, and the program begins executing.
Using mainboard GHI Electronics FEZRaptor version 1.0
Message from Class Bluetooth 1: Baudrate set to 38400
Message from Class Bluetooth: Try to set BT-Module baudrate to: 38400
Message from Class Bluetooth: Could connect to BT-Module with baudrate 38400 in 16.561600000000002 msec
Program Started
Client Mode
Enter Pairing Mode
Bluetooth State Changed to :1
5. Output window shows:
Found debugger!
Create TS.
Loading start at 202ce7d4, end 202fd79c
Assembly: mscorlib (4.2.0.0) Assembly: Microsoft.SPOT.Native (4.2.0.0) Assembly: Microsoft.SPOT.Security.PKCS11 (4.2
.0.0) Assembly: System.Security (4.2.0.0) Assembly: Microsoft.SPOT.Hardware (4.2.0.0)
Assembly: Microsoft.SPOT.Graphics (4.2.0.0) Assembly: Microsoft.SPOT.TinyCore (4.2.0.0)
Assembly: Microsoft.SPOT.IO (4.2.0.0) Assembly: System.IO (4.2.0.0) Assembly: Microsoft.SPOT.Hardware.Usb (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0) Assembly: Microsoft.SPOT.Touch (4.2.0.0)
Assembly: Microsoft.SPOT.Ink (4.2.0.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1)
Attaching deployed file.
Assembly: Microsoft.VisualBasic (1.0.0.0) Attaching deployed file.
Assembly: Gadgeteer (2.42.0.0) Attaching deployed file.
Assembly: Bluetooth (1.0.0.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.Bluetooth (4.2.102.0) Attaching deployed file.
Assembly: Gadgeteer.Serial (2.42.0.0) Attaching deployed file.
Assembly: Bluetooth_Pairing_Test (1.0.0.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.UsbClientDP (4.2.102.0) Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZRaptor (4.2.102.0) Attaching deployed file.
Assembly: GHI.Premium.IO (4.2.11.1) Attaching deployed file.
Assembly: Microsoft.SPOT.Net (4.2.0.0) Attaching deployed file.
Assembly: GHI.Premium.Hardware (4.2.11.1) Attaching deployed file.
Assembly: GHI.Premium.System (4.2.11.1) Attaching deployed file.
Assembly: GTM.GHIElectronics.Display_T43 (4.2.102.0) Resolving.
GC: 1msec 277536 bytes used, 66828228 bytes available
Type 0F (STRING ): 24 bytes
Type 15 (FREEBLOCK ): 66828228 bytes
Type 17 (ASSEMBLY ): 33120 bytes
Type 1E (BINARY_BLOB_HEAD ): 244320 bytes
GC: performing heap compaction...
Ready.
