In order to enable the USB client, I need to configure my Panda II to use serial debugging (even though I’m not actually using debugging at all). The beginners guide mentions jumpering the MODE jumper (or LMODE pin) to 3.3V, but it does not mention the Panda II and what pin should be used / connected to what.
So could I get some instructions for a Newbie to use USB client without debugging. I have no rs232 shield.
I am on FEZ PANDA 2
Program is installed by debugger. My program waits to get out of usbdebugger mode
here is code snippet
OutputPort led = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.Di51, true);
I put 1k resistor between mode and ground, and 1k resistor between com rx and 3v3.
I reset by pressing loader /reset [ or by using watchdog feature]
My program runs its usb stuff…
[now when I want to debug again I just remove connector between mode and ground
and again press loader/reset]
OK and this is where I am confused… I feel I have to unplug the usb connection for the serial port to be recognised, but I haven’t quite worked it out… I go through some random cycle of resetting / unplugging and eventually teraterm recognises the serial link.
would value a clear explanation of what i need to do to get the CDC serial port to be recognised by my PC.
