HI,
I recently purchased a FEZ Panda II.
I followed the procedures of updating the firmware but now the device is not recognized…not from
MFDeploy and not by TeraTerm either.
Please note that I’m not a newbie, I also have a Fez Panda that works great.
Is it possible that somehow the device is “bricked” ?
Theo
What do you see in device manager?
Connect it directly to pc with no hubs
Well, I deleted and re-installed the USB drivers, Windows recognized it in COM7, and with
USBiziUpdater I loaded the firmware.
It is recognizable now, I managed to upload some code also, but I have two issues:
- The MFDeploy package reads and pings the Panda ok, but when I press the Device Capabilities
option it states that the device is not supported.
- When I connect it to teraTerm, it still sends BL.
and also, the LED is steady on, not blinking.
Any ideas about these issues?
thanks!
theo
Updated,
I connected the device now and Windows does not recognize it, I get an error that the device is not
recognzable.
I will try once again, but I think it is already damaged, probably the firmware was not updated properly…
anything to do about it?
thanks!
theo
[quote]I will try once again, but I think it is already damaged, probably the firmware was not updated properly…
[/quote]
GHI design boards so they are near indestructible I doubt you bricked the board doing an update.
The LED will not be blinking, that is normal!
Please follow this http://wiki.tinyclr.com/index.php?title=Firmware_Update
Theodoros
Can you try to attach the Panda to another computer and go thorugh all the steps ?
I feel that your computer is the biggest variable in this scenario.
HTH
-Rajesh
