Hello everyone, a fairly long time ago I looked how to use the arduino ethernet shield with my FEZ Panda, and i found that i have to make some modifications to the shield to use it. Now i got a Panda II, and i want to use the same shield, and i thought that i have to make tha same adjustments, is that correct? … assuming that it is, the forum topic was deleted … does anyone have that details?
Ok good. This one should be using the SPI pins like it should. No modification is needed on it except it is better if you wire reset to an IO and control it on power up.
