I just recieved my FEZ Panda, but when I plug it into USB, the IC3 get’s vey hot (>100 °C) within seconds. Is this normal, how can I fix it? Should I send it back?
The board works normal otherwise…i.e. I can ping it and check the firmware version. I only tested it for a few seconds, because it really, really gets hot.
Please contact GHI directly for further steps. Boards are tested ab packaged right before they ship but we will work something out to make sure you are happy.
My FEZ Panda I just received loads and runs code (for now) but becomes extremely hot during use. I think the heat is coming from one of the smd voltage regulators. I have not left it plugged in via usb for very long because I start to smell burning plastic after a while.
It cant be very safe for the device or me because any touching during operation causes burns to my hand
Just hooked up 4 AA batteries via the barrel jack and am not getting the same problem. Gets warm but nothing unusual among regulators that I have worked with
Looking at the traces its not obvious where the power problem is
just compared my board with the schematic to try and figure out what the problem is
One difference between my board and the schematic is that there is no R2 present (the resistor associated with IC3, the IC that is generating all of the heat
Is the fact R2 is missing a manufacturing defect or was it intentionally left out
so…would it be possible to swap boards out? Or what is the ultimate solution to this problem?
I really want to start developing on my board. I am planning on using it for my group senior design project for next semester and I want to start getting familiar with it.
I am hesitant because I do not want to fry it (or my USB controller for that matter)
I think the following is the problem:
When the input pin of the 5V regulator is lower than the 5V, the IC3 is not working and some of the internal transistors are floating/leaking the current from the output to common ground. This heats the device. The thermal shutdown is not active in this mode, because -as I said- the device is not working in normal mode. If my USB port would supply more current, I’m sure it could desolder itself from the board.
When you connect a 12V power-supply, the input pin of the 5V regulator is high enough and the device works normally.
The only fix is to change the IC3 with a device that tollerates these operating conditions.
Ok, there is something weird going on with that voltage regulator. An hour ago, the behaviour of my FEZ Panda changed. Now the IC3 gets hot when I plug use the 12V plug, but stays cold when I power it from USB. I don’t know what caused that change.
Chris_, your problem is not related to post Gus mentioned.
What do you have connected to your FEZ Panda? If you have likeEthernet shiled or display connected to, then you need to use 6 or 7.5 Volts to power it.
The reason is, the more the power consumpltion the more heat the regulator should dissipate.
No, I only have the bare Panda board connected. The only cable connected is a stabilized 12 V power source. It overheats in seconds.
I’ll request a replacement.
