Is the FEZMini_GHIElectronics.NETMF.FEZ documented ( no point me doing things myself with the GHI assemblies if it’s already in the FEZ min assembly) Thanks.
This assembly is not documents as it doesn’t have anything in it beside the pins enumerations. All other assemblies are documented (see link on the right).
I am not exactly sure what you are trying to do so I can help you better!
Thanks, I don’t have any specific project, just curious to know what the assembly contains so I don’t spend time writing unnecessarily code.
OK I see. You actually do not care what is in this particular assembly. All info you really need is documented in the GHI library documentation and also take a look at Microsoft documentation for NETMF.
