Hallo
Can i use the FEZ medusa Shield on top of the Arduino DUE-board instead of put the FEZ medusa shield on top of the Arduno Uno board?
Jack.
Hallo
Jack.
It should work but we haven’t tested it. You will need to make few changes on the software maybe.
Why not use the shield 3D?
For the most part this will work, however, the SPI pins on the DUE are only exposed along the 6-pin header towards the middle of the board, unlike the UNO. You would loose SPI functionality all together.
As Gus said, I would use the Shield 3D. All the sockets on the 3D are native, so you will also see a slight performance boost from that as well.
