I’m a student at the university of Antwerp and I’m having some troubles.
I want to create a bluetooth-connection using the Arduino due, combined with the Fez Medusa Shield 3D and a gadgeteer Bluetooth 1.1 module.
When I compile and upload my code, I can’t find any bluetooth connection and there is nothing printed in my serial monitor.
@ Verspeeks - Regretfully the Medusa has been discontinued for some time. Not all of the module drivers were ever fully completed or tested, especially the Bluetooth module. I would not rely on the driver we provided in the only SDK release (which I believe was a beta) as working.
@ Verspeeks - Since it was discontinued, we never finished the driver. You can find the source at https://bitbucket.org/ghi_elect/gadgeteering if you want to investigate it yourself.
@ Verspeeks - The BT module should work on any Gadgeteer mainboard. I’m not sure if there is a driver for 4.3, but there is an effort in the community to bring discontinued modules up to the latest version.
@ Ro Schmi - Can I use this driver while programming in the Arduino IDE?
Or can I program the Arduino Due + Fez Medusa shield using micro framework?
Because I tried to use it, but I didn’t found the wright way to do it…
I think your problem is about versioning. You mention 4.2, is there any reason you’re trying to use that rather than move to the latest 4.3 ? Gadgeteer.Interfaces is possibly a 4.3 namespace.
Because I’m still a newbie I can’t figure out this problem:
How can I send data from my Spider to any bluetooth device using the bluetooth module?
I did take a look at your driver and your test-program, but it doesnt seem to work…
In the end I would like to make a program that constantly sends data from my Spider to a bluetoothdevice.
