For the Fez Lemur Device Manger for Windows 7 shows "Other Devices > G30 and “The drivers for this device are not installed. (Code 28)”.
Where can I find a driver for the Fez Lemur G30?
hrh1818
hrh1818
Installation of “GHI Electronics NETMF SDK 2015 R1 Pre-Release 4” produced a Setup Failed report. I counted 13 errors in the Log File.
hfrh1818
@ hrh1818 - what did the errors say? did you completely remove the prior release?
I had not previously installed the Gadgeter software as using a Fez Lemur.
Here is the section of the log file that contained errors
[1CF4:14B4][2015-08-02T14:51:35]i338: Acquiring package: sam_ba.2.12.exe, payload: sam_ba.2.12.exe, download from: https://www.ghielectronics.com/downloads/NETMF/SDK/sam-ba.2.12.exe
[1CF4:14B4][2015-08-02T14:51:55]e000: Error 0x80072f19: Failed to send request to URL: https://www.ghielectronics.com/downloads/NETMF/SDK/sam-ba.2.12.exe, trying to process HTTP status code anyway.
[1CF4:14B4][2015-08-02T14:51:55]e000: Error 0x80072f19: Unknown HTTP status code 0, returned from URL: https://www.ghielectronics.com/downloads/NETMF/SDK/sam-ba.2.12.exe
[1CF4:14B4][2015-08-02T14:51:55]e000: Error 0x80072f19: Failed attempt to download URL: ‘https://www.ghielectronics.com/downloads/NETMF/SDK/sam-ba.2.12.exe’ to: ‘C:\Users\Howard\AppData\Local\Temp{2dfd46a8-2a23-4532-bea5-49414a4bc2e1}\sam_ba.2.12.exe’
[1CF4:14B4][2015-08-02T14:51:55]w343: Prompt for source of package: sam_ba.2.12.exe, payload: sam_ba.2.12.exe, path: C:\Users\Howard\Documents\GHI Electronics\sam-ba.2.12.exe
[1CF4:14B4][2015-08-02T14:51:58]i338: Acquiring package: sam_ba.2.12.ex
[1CF4:14B4][2015-08-02T14:51:58]e000: Error 0x80072f19: Failed to send request to URL: https://www.ghielectronics.com/downloads/NETMF/SDK/sam-ba.2.12.exe, trying to process HTTP status code anyway.
[1CF4:14B4][2015-08-02T14:51:58]e000: Error 0x80072f19: Unknown HTTP status code 0, returned from URL: https://www.ghielectronics.com/downloads/NETMF/SDK/sam-ba.2.12.exe
[1CF4:14B4][2015-08-02T14:51:58]e000: Error 0x80072f19: Failed attempt to download URL: ‘https://www.ghielectronics.com/downloads/NETMF/SDK/sam-ba.2.12.exe’ to: ‘C:\Users\Howard\AppData\Local\Temp{2dfd46a8-2a23-4532-bea5-49414a4bc2e1}\sam_ba.2.12.exe’
[1CF4:14B4][2015-08-02T14:51:58]w343: Prompt for source of package: sam_ba.2.12.exe, payload: sam_ba.2.12.exe, path: C:\Users\Howard\Documents\GHI Electronics\sam-ba.2.12.exe
[1CF4:14B4][2015-08-02T14:52:01]i338: Acquiring package: sam_ba.2.12.exe, payload: sam_ba.2.12.exe, download from: https://www.ghielectronics.com/downloads/NETMF/SDK/sam-ba.2.12.exe
[1CF4:14B4][2015-08-02T14:52:02]e000: Error 0x80072f19: Failed to send request to URL: https://www.ghielectronics.com/downloads/NETMF/SDK/sam-ba.2.12.exe, trying to process HTTP status code anyway.
[1CF4:14B4][2015-08-02T14:52:02]e000: Error 0x80072f19: Unknown HTTP status code 0, returned from URL: https://www.ghielectronics.com/downloads/NETMF/SDK/sam-ba.2.12.exe
[1CF4:14B4][2015-08-02T14:52:02]e000: Error 0x80072f19: Failed attempt to download URL: ‘https://www.ghielectronics.com/downloads/NETMF/SDK/sam-ba.2.12.exe’ to: ‘C:\Users\Howard\AppData\Local\Temp{2dfd46a8-2a23-4532-bea5-49414a4bc2e1}\sam_ba.2.12.exe’
[1CF4:14B4][2015-08-02T14:52:02]w343: Prompt for source of package: sam_ba.2.12.exe, payload: sam_ba.2.12.exe, path: C:\Users\Howard\Documents\GHI Electronics\sam-ba.2.12.exe
[1CF4:14B4][2015-08-02T14:52:05]i338: Acquiring package: sam_ba.2.12.exe, payload: sam_ba.2.12.exe, download from: https://www.ghielectronics.com/downloads/NETMF/SDK/sam-ba.2.12.exe
[1CF4:14B4][2015-08-02T14:52:05]e000: Error 0x80072f19: Failed to send request to URL: https://www.ghielectronics.com/downloads/NETMF/SDK/sam-ba.2.12.exe, trying to process HTTP status code anyway.
[1CF4:14B4][2015-08-02T14:52:05]e000: Error 0x80072f19: Unknown HTTP status code 0, returned from URL: https://www.ghielectronics.com/downloads/NETMF/SDK/sam-ba.2.12.exe
[1CF4:14B4][2015-08-02T14:52:05]e000: Error 0x80072f19: Failed attempt to download URL: ‘https://www.ghielectronics.com/downloads/NETMF/SDK/sam-ba.2.12.exe’ to: ‘C:\Users\Howard\AppData\Local\Temp{2dfd46a8-2a23-4532-bea5-49414a4bc2e1}\sam_ba.2.12.exe’
[1CF4:14B4][2015-08-02T14:52:05]e000: Error 0x80072f19: Failed to acquire payload from: ‘https://www.ghielectronics.com/downloads/NETMF/SDK/sam-ba.2.12.exe’ to working path: ‘C:\Users\Howard\AppData\Local\Temp{2dfd46a8-2a23-4532-bea5-49414a4bc2e1}\sam_ba.2.12.exe’
[1CF4:14B4][2015-08-02T14:52:05]e313: Failed to acquire payload: sam_ba.2.12.exe to working path: C:\Users\Howard\AppData\Local\Temp{2dfd46a8-2a23-4532-bea5-49414a4bc2e1}\sam_ba.2.12.exe, error: 0x80072f19.
[1CF4:1E78][2015-08-02T14:52:05]e000: Error 0x80072f19: Failed while caching, aborting execution.
[0B98:1C84][2015-08-02T14:52:05]i330: Removed bundle dependency provider: {2dfd46a8-2a23-4532-bea5-49414a4bc2e1}
[0B98:1C84][2015-08-02T14:52:05]i352: Removing cached bundle: {2dfd46a8-2a23-4532-bea5-49414a4bc2e1}, from path: C:\ProgramData\Package Cache{2dfd46a8-2a23-4532-bea5-49414a4bc2e1}\
[1CF4:1E78][2015-08-02T14:52:05]i399: Apply complete, result: 0x80072f19, restart: None, ba requested restart: No
hrh1818
@ hrh1818 - It looks like it wasn’t able to download the FEZ Hydra/G400 Loader Updater. Since you are using the FEZ Lemur, you can uncheck it from the Advanced menu in the installer. Alternatively, you can install it from https://www.ghielectronics.com/downloads/NETMF/SDK/sam-ba.2.12.exe if you need it.
Hello Gus,
Once again your reply was on the mark. In the advanced configuration dialog I also unchecked Gadgeteer options in addition to the Hyfdra updater option and successfully installed “GHI Electronics NETMF SDK 2015 R1 Pre-Release 4”. Following the installation I successfully deployed a project.
It looks like if I need Gadgeteer capability in the future I can add it by using the Repair option the installation wizard.
Thank your help
hrh1818
@ hrh1818 - do you mean John?
Yes I made a mistake and gave the wrong person credit for the advice for fixing my driver issue.
Thanks John your advice was on the mark
hrh1818
