So far I had no problems with running T43 display with FEZ Hydra, but after update to new TinyCLR (I uninstall everything before it), I cannot make display to work.
It’s only white.
When going back to 4.2.6.1 it works again, but I cannot remove version 4.2.6.2 completely from system and it gets there somehow (I bet with my program) and after some time, display stops working again ???
I hope someone could help me cause I dont want to reinstall the whole OS.
The “all white” symptom is documented in the release notes. The firmware no longer initialises the display by default, so you need to do so in code. Once you do that, it will work as usual.
To be honest, I had an issue. When initializing T43 in gadgeteer in debug mode, debug ended and I couldnt debug anymore so I tried to play with preprocessors directives not to intialize display in debug mode.
Now I am back on 4.6.4.1.
I will try new version again, but I am not sure if it will work properly.
