Hydra board: Rev 1.2 Firmware 4.2.8
I wanted to do a quick test on Hydra with Onewire with the Feb.1st 2013 update… Unfortunately “quick” was a wrong assumption
Following the instructions to reset the hydra results in an error dialog … The only way to stop is to select cancel… And no, there’s is only one hydra connected to my computer…
Any idea someone… I removed all GHI software, Removed all USB drivers using USBdeview and resinstalled all GHI software new.
UPDATE:
Solved this issue by:
- de-installing all GHI software
- removing all USB drivers using USBdeview.exe
- manually deleted all folders C:\Program files\GHI Electronics
- Reboot system
- Install GHI SDK 4.2.8
Done…
