Gentlemen
I try to update my Hydra V1.2 and I’m folowing the steps described here: https://www.ghielectronics.com/docs/125/firmware-update-fez-hydra
I’m struggleing at step “Loading Bootstrap” because it fails or hangs. The output is
-I- Waiting …
-I- TCL platform : Windows NT
-I- SAM-BA CDC 2.10 on : windows
-I- Retrieved arguments from command line :
-I- argv 0 : com9
-I- argv 1 : at91sam9rl64-ek
-I- argv 2 : TinyBooterLoader.tcl
-I- Connection : com9 (target(comType) = 3)
-I- Board : at91sam9rl64-ek
-I- Traces Level : 4
-I- target(handle) : file28bda30
Read device Chip ID at 0xfffff240 — get 0x019b03a0
-I- Found processor : at91sam9rl64 (Chip ID : 0x019b03a0)
-I- Command line mode : Execute script file : TinyBooterLoader.tcl
-I---------------------------------
-I- GHI Electronics, FEZ Hydra -
-I- TinyBooter Updater Script -
-I Enable DataFlash
-I- DATAFLASH::Init 0 (trace level : 4)
-I- Loading applet isp-dataflash-fez_hydra.bin at address 0x300000
-I- Memory Size : 0x420000 bytes
-I- Buffer address : 0x302CD8
-I- Buffer size: 0x18C0 bytes
-I- Applet initialization done
-I- Erasing: 0x18C0 bytes at address 0x0
-I- Erasing: 0x18C0 bytes at address 0x18C0
-I- Erasing: 0x18C0 bytes at address 0x3180
-I- Erasing: 0x18C0 bytes at address 0x4A40
-I- Erasing: 0x18C0 bytes at address 0x6300
The process doesn’t open the notepad with the logfile, so I assume, the process is still running.
Does anyone of you have the same issue and a solution of it ?
Kind regards
Josch
