FEZ Hydra firmware is finally here but for testing purposes only. Please read this page (which also directs you to the firmware update page) GHI Electronics – Where Hardware Meets Software
Please give it a try and let us know what you find ASAP. This should have the button and LED fixes if you have FEZ Spider.
Edit: new release us up and this thread is locked.
All design files (hardware/software) are published. The wiki above explains it all.
Beta testers, please help! Can you everyone who has hydra confirm back to this post if they have updated the firmware and they are able to use it with some modules?
Oh No! Gus I’m getting failures all over the place here.
I updated the firmware first off.
Attached SD module (with or without card) and get
"An unhandled exception of type ‘System.Exception’ occurred in Microsoft.SPOT.Hardware.dll"
happens on: sdCard = new GTM.GHIElectronics.SDCard(8);
I have double checked I do have it plugged into the right socket.
A first chance exception of type ‘Gadgeteer.Socket.InvalidSocketException’ occurred in GTM.GHIElectronics.SDCard.dll
Invalid address 20300570 and range 4 Ram Start 31000000, Ram end 35000000
Invalid address 203005d0 and range 4 Ram Start 31000000, Ram end 35000000
#### Exception System.Exception - CLR_E_DRIVER_NOT_REGISTERED (2) ####
#### Message:
#### Microsoft.SPOT.Hardware.NativeEventDispatcher::.ctor [IP: 0000] ####
#### GHIElectronics.NETMF.System.InternalEvent::.cctor [IP: 0014] ####
I get a similar fail on buttons. I lets me proceed w/ button but then the second I press it and trigger the interrupt " Invalid address 20308d84 and range 4 Ram Start 31000000, Ram end 35000000" and everything stops.
@ skewworks you get spot errors!?? You are loading on SD to erase the device. As for firmware, it is far from complete. It doesn’t have SD drivers for example.
@ mike leave the jumper in and follow the steps please.
You just ruined the rest of my week… So, there’s no way to get the firmware on w/o having the SD card module? Wish we had been warned of this a week ago.
