Hi
My computeur does not recognize my device “FezHydra” (first picture)
My Usb CLient SP works correctly.
This problem appeared when I deployed an application. It took more time to deploy than usually (second picture) .
So, I cliked on generate and then cancel. My FezHydra does work since.
Do you have a clue why it does not work ? I really need help ? Did it happen to any of you too?
Ok, Maybe try putting the Hydra into bootloader mode (as if you were going to re flash the firmware) see if its detected then.
If it is then i would follow the steps for re flashing anyway, that should put it back to a clean state.
Edit: make sure you follow the directions to the letter for updating the firmware, and dont unplug it while its flashing or your Hydra will become a nice collection of spare parts for another Hydra
