I have just received a FEZ Hydra board and tried to create an application.
I got following errors:
[quote]Create TS.
Loading start at 20175a40, end 201a2d84
Assembly: mscorlib (4.2.0.0) Assembly: Microsoft.SPOT.Native (4.2.0.0) Assembly: Microsoft.SPOT.Hardware (4.2.0.0)
Assembly: Microsoft.SPOT.Graphics (4.2.0.0) Assembly: Microsoft.SPOT.TinyCore (4.2.0.0)
Assembly: Microsoft.SPOT.IO (4.2.0.0) Assembly: System.IO (4.2.0.0) Assembly: Microsoft.SPOT.Hardware.Usb (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0) Assembly: Microsoft.SPOT.Touch (4.2.0.0)
Assembly: Microsoft.SPOT.Ink (4.2.0.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1)
Assembly: Microsoft.SPOT.Hardware.OneWire (4.2.0.0) Assembly: System.Xml (4.2.0.0)
Assembly: Microsoft.SPOT.Time (4.2.0.0) Assembly: Microsoft.SPOT.Net (4.2.0.0)
Assembly: System (4.2.0.0) Assembly: Microsoft.SPOT.Net.Security (4.2.0.0)
Assembly: System.Net.Security (4.2.0.0) Loading Deployment Assemblies.
Attaching deployed file.
Assembly: Gadgeteer (2.42.0.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.SDCard (1.1.2.0) Attaching deployed file.
Assembly: InternetRadio (1.0.0.0) Attaching deployed file.
Assembly: Gadgeteer.SPI (2.42.0.0) Attaching deployed file.
Assembly: System.Http (4.2.0.0) Attaching deployed file.
Assembly: GHI.OSHW.Hardware (4.2.5.0) ***********************************************************************
ERROR!!! Firmware version does not match managed code version!!! *
Invalid native checksum: GHI.OSHW.Hardware 0xF75E8662!=0xF0D4135D *
Resolving.
Assembly: InternetRadio (1.0.0.0) needs assembly âGTM.GHIElectronics.Musicâ (1.1.3.0)
Assembly: InternetRadio (1.0.0.0) needs assembly âGTM.GHIElectronics.UsbClientSPâ (1.1.2.0)
Assembly: InternetRadio (1.0.0.0) needs assembly âGHIElectronics.Gadgeteer.FEZHydraâ (1.1.3.0)
Error: a3000000
Waiting for debug commandsâŚ
The program â[2] Micro Framework application: Managedâ has exited with code 0 (0x0).
[/quote]
So, I tried to update the firmware of the hydra using the âFEZ Config v013â application.
In the middle of the firmware update, the board lost its connection automatically and the update failed.
Now every time since it failed updating the firmware, I get the following error:
Failure - Device is not connected or not responding.
Is there any way to get rid of this problem?
Thanks,
Mazhar
