Fez Hydra - Com debugging
I don’t see the manner to use COM port for degguging instead of usb!!!
This function doesn’t exist on Fez Hydra?
No it is not supported on Hydra.
Outch…
Then I can’t use usb client class because I can’t debug or deploy on the same port than CDC!!!
You need to use usb to serial module http://www.ghielectronics.com/catalog/product/287
Ok, then usb client on Hydra is ONLY for debugging and deployement?
No. You can use it for other purposes (mainly HID) if you switch to use serial for deploying.
then why architect tell me that the functionnnality is not implemented?
I think I have tried it before, but it was awhile ago. I have double check again. Anyways Gus knows better, try it.
This is untested. Latest firmware has serial debug option but if you really need to use USB client then you need one of the premium offers.
