I am doing my first steps on the Micro Framework 4.2 withg FEZ Hydra. Until today I were successful in learning and trying step by step. But suddenly Visual Studio 2012 won’t debug any more on the hardware.
Perhaps a complete reflashing of the TinyBooter and the micro framework would help. The manual reset of the firmware was successful so far(https://www.ghielectronics.com/docs/125/firmware-update-fez-hydra), but then FEZ Config won’t install/update the firmware. So currently only the TinyBooter is running. If I use FEZ Config to deploy a firmware the follwing error occurs, see screenshot…
Is the Hydra bricked? Another power source does not help.
My system contains the FEZ Hydra with USB Client DP module and ENC28 ethernet.
Any help would be appreciated! Thank you!
Best regards
