Hi All,
I’ve recently dusted off a bunch of stuff from GHI, from my Last post this was 5 years ago.
So grabbing the latest sdks etc, im getting a bunch of issues that i don’t remember having all those years ago.
Examples:
Gyro and Barometer not firing the MeasurementComplete events
Bunch of Classes obsolete ( DisplayT35, Barometer) - Not sure if this is due to the disbanding of Gadgeter or that the TE35 replaced it.
When i do run:
#### Exception System.NullReferenceException - CLR_E_NULL_REFERENCE (1) ####
#### Message:
#### Gadgeteer.Modules.Module+DisplayModule::OnDisplayConnected [IP: 0023] ####
#### Gadgeteer.Modules.GHIElectronics.DisplayT35::.ctor [IP: 0071] ####
#### Gadgeteer.Modules.GHIElectronics.DisplayT35::.ctor [IP: 000a] ####
#### MFConsoleApplication4.Program::Main [IP: 0015] ####
A first chance exception of type ‘System.NullReferenceException’ occurred in Gadgeteer.dll
DisplayT35 ERROR : A display ‘Display T35’ with resolution 320×240 and 0 orientation was connected. However, the mainboard is unable to fulfil its requirements.
So my questions, which is a good version of firmware/sdk i should target to be able to play once again.
Regards
John
