According to build 10556 release notes rx/tx are supported on pi2. Unless these are not used for UART, it might well be worth a test to see if it works after the last insider build (10/15)
I haven’t found time to do any test yet, but I’ll definately try it with the xbees to see if it is working …
Even if this wouldn’t work, it is still doable using a small USB-Serial converter. That’s how I got my xbees to communicate with the serial example from github.
Yup, I open Azure portal and — bam! — it’s like 25 tabs staring at me! Why a Service Bus is a “Bus”? And why Event Hub is a “Hub”? And then it’s only storage, I need a data cruncher and visualizer Power BI, which is a completely different thing that took me 2 days to finally get in and I still don’t know how did it happen in the end.
So, I felt a lot like a poor secretary, following the guide line-by-line praying that there are no typos and mistakes in it
Obviously, Azure is a big thing needing big books to read…
For those who want to capture the PI2’s HDMI via USB3 in full HD the AVerMedia ExtremeCap U3 does do a good job. In this case no seperate display required it’s all on you monitor … :dance:
@ devhammer - haven’t figured out how to use the mouse/keyboard of the capturing window to be treated as if they were the mouse/keyboard of the PI so I still have a seperate keyboard for the PI …
