I need to hook up two FEZ Dominos using XBee. One Domino (the remote) is used to read sensor data and transmit the data to a master using the XBee. The other domino called the master, using also XBee, will be receiving the data from the remote domino. The master is attached to a PC through the USB port and will post the data read from the remote sensor into a Windows application. The master in a second phase must be able to work stand alone and post the data as a web server in the Internet.
The remote Domino uses the LCD & Keypad Shield, must have the XBee, and be powered through an external adapter.
The master Domino may use a touch screen graphical display, must have the XBee, and be powered through an external adapter. For this phase, I may use similar hardware as the remote. But based on your recommendation I may change my mind.
The system may be expanded to use multiple remotes.
Q: Can you recommend me the list of GHI components needed to implement this system?
Regards,
Eduardo
