Hello, I have FEZ Domino board and I like to measure pulses or Voltage values on the Digital and Analogue input ports, so I use the FEZDomono-EXP board but can I connect the LCD Keypad Shield board on the top of these two boards without damage anything.
( Is there also a drawing from FEZDomono-EXP board available)
Okay thanks, but when I create a project with some shields and these shields are stacked up, it is better to look at the schematics of each shields or some shields are using the same pins.
So where can I find the schematic of the FEZDomino-EXP shield?
You said you wanted to measure pulses… .NETMF is not the best environment for pulse measurements. Too much going on internally which can mess up pulse measurements.
