Hello, I am new to FEZ boards in general. Just started to mess with it few days ago.
I want to use this Transceiver/Antenna with Domino.
http://www.sparkfun.com/products/691
In the end, I want to use another one to send data from device A to FEZ board, which in the end would send it to PC (like Terminal).
Did anyone used it with FEZ Domino? How can I send received data (by this transceiver) and send it over USB host port to PC Terminal?
Sam
December 10, 2010, 9:28pm
2
have you look into this one yet??
[url]microframeworkprojects.com
I am not sure what exactly you are looking for This is a very old project that may help you? microframeworkprojects.com
Please ask specif questions instead of general questions so we can help you better. See this please http://www.tinyclr.com/forum/1/1904/
thank you for this links.
Do you think different configuration of boards with Nordic (like the one I mentioned or the one in the tutorial) will have similar method of application? (to make them work with FEZ)
Almost anything can work whit FEZ, it is a matter of wiring things properly and writing some code
Do I need to have 2nd Nordic transceiver/antenna to receive data from another board (which has same Nordic transceiver connected)?
Or can I somehow receive the data from Nordic by wifi on the PC or something like this?
