FEZ Cream and "Temp&Humidity Module - .NET Gadgeteer Compatible" from Seeed Studio
Hello,
i have Raspberry Pi 3 Modell B and GHI FEZ Cream. One of my sensors is “Temp&Humidity Module - .NET Gadgeteer Compatible” from Seeed Studio. There is no Support for this module in GHIElectronics.UWP.Gadgeteer.Modules.
Can anyone tell my how to use this sensor with FEZ Cream?
Thanks for any help,
Jörg
I don’t know which sensor is on this module. Perhaps it could be replaced with:
            _mainboard = await Module.CreateAsync<FEZCream>();
            _temp = await Module.CreateAsync<TempHumidSI70>();
Next _temp is your module. If it doesn’t work, you have to play i2c device.
This is just a clue not I answer I know.
Don’t hesitate to ask.
@ iXsystems - We have not provided a driver for that module. If you want to use it, you will have to port the driver from NETMF to Windows 10 IoT Core.
You can start with the NETMF driver at https://bitbucket.org/ghi_elect/gadgeteer/src/eba1405f769bd03e7241b5ca8cc305d5a4ba4be1/Modules/GHIElectronics/TempHumidity/TempHumidity_43/TempHumidity_43.cs?at=master&fileviewer=file-view-default
The drivers at https://bitbucket.org/ghi_elect/windows-iot/src/446f393eff4a92ebd27eddae96c9a02c2476d18b/GHIElectronics.UWP.Gadgeteer/?at=master can be used as a reference for writing a driver using the FEZ Cream.
