Hi.
We’ve just put our hands on a brand new FezCerbuinoNET.
We updated firmware to 4.2.6.1 (we left 4.2.6.0 tinybooter), Ethernet-enabled “flavor”.
We managed to configure network parameters (DHCP enabled), but whenever we run a simple test like following socket.Connect() method hangs forever:
public void Connect()
this.socket = new Socket(this.remoteIpAddress.GetAddressFamily(), SocketType.Stream, ProtocolType.Tcp);
// try connection to the broker
this.socket.Connect(new IPEndPoint(this.remoteIpAddress, this.remotePort));
Any hints?
Thanks!
@ andre.m. Thanks for your support.
Same source code runs fine on a Netduino2+ connected to same switch.
I’m going to try with a Cerbuino Bee with ENCj28 gadgeteer module and with a Mountaineer Eth…
@ Innovactive - Looks like it has been fixed in NETMF 4.3.
If your Netduino2+ is running 4.3 that would explain why it works.
I see, but that’s not the point, since the host I’m trying to connect is actually up and listening (168.63.59.42, port 1883).
@ Architect: ND2+ is running NETMF 4.2, so I expect that if the server is down socket.connect() hangs there, too.
Is FezCerbuinoNET exactly like a CerbuinoBee+ENCj28 Gadgeteer Module connected to socket 1 from a “pinout” perspective?
