FEZ Cerbuino Net Multicast Join
Hello and thank you in advance for your time.
I have a FEZ Cerbuino Net and I am trying to join a multicast group. The following codes executes without error but the devices doesn’t actually register as joining the multicast group in wireshark.
Till now I have been trying with a netduino but it crashes when you try and set ttl or join the group. With the code below I set the ttl and then read it back and it is successful.
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
using System.Net;
using System.Net.Sockets;
namespace GadgeteerApp2
    public partial class Program
        InterruptPort x;
            NetworkChange.NetworkAddressChanged += NetworkChange_NetworkAddressChanged;
            NetworkChange.NetworkAvailabilityChanged += NetworkChange_NetworkAvailabilityChanged;
            Mainboard.Ethernet.EnableDhcp();
            Mainboard.Ethernet.EnableDynamicDns();
          //  Mainboard.Ethernet.RenewDhcpLease();
            Mainboard.Ethernet.Open();
            Debug.Print(Mainboard.Ethernet.IPAddress);
            IPAddress anyIPAddr = IPAddress.Any;
            IPEndPoint endPoint = new IPEndPoint(anyIPAddr, 9000);
            System.Net.Sockets.Socket socket = new System.Net.Sockets.Socket(AddressFamily.InterNetwork, SocketType.Dgram, ProtocolType.Udp);
            socket.SetSocketOption(SocketOptionLevel.Socket, SocketOptionName.ReuseAddress, 1);
            socket.Bind(endPoint);
            byte[] discoveryAddr = IPAddress.Parse("239.255.255.0").GetAddressBytes();  // administratively scoped IPv4 multicast address
            byte[] ipAddr = IPAddress.Any.GetAddressBytes();
            byte[] multicastOpt = new byte[] {  discoveryAddr[0], discoveryAddr[1], discoveryAddr[2], discoveryAddr[3], ipAddr[0], ipAddr[1], ipAddr[2], ipAddr[3] }; // Local IPAddress
            Debug.Print("Setting Multicast");
              socket.SetSocketOption(SocketOptionLevel.IP, SocketOptionName.AddMembership, multicastOpt);
              socket.SetSocketOption(SocketOptionLevel.IP, SocketOptionName.MulticastTimeToLive, 32);
            Debug.Print("Multicast TTL is " + socket.GetSocketOption(SocketOptionLevel.IP, SocketOptionName.MulticastTimeToLive));
        void NetworkChange_NetworkAvailabilityChanged(object sender, NetworkAvailabilityEventArgs e)
            Debug.Print("NetworkChange_NetworkAvailabilityChanged");
        void NetworkChange_NetworkAddressChanged(object sender, EventArgs e)
           Debug.Print("NetworkChange_NetworkAddressChanged");
Ps.
If the Cerbuino board won’t handle multicast is there a board that will? As multicast is a deal breaker for this project.
Thanks again.
Hey Team.
Looks like it’s actually working, there is now membership report in wireshark but the device is receiving Multicast traffic.
Cheers
