Fez Cerbuino Bee old documentation
Hi everybody,
I used to develop on FEZ Domino some years ago with no problems.
Now I have to develop a very small simply code for a FEZ Cerbuino Bee board, just using the digital outputs.
I know that this system is obsolete but why removing the old documentation?
Is there any way of obtaining the Developer guide? (Old link was ghielectronics.com/docs/45/fez-cerbuino-bee-developer)
There exist any example code specifically working for FEZ Cerbuino Bee board?
Thank you and best regards
@ jbermudez - Here you go: [url]https://web.archive.org/web/20130424183948/http://www.ghielectronics.com/docs/45/fez-cerbuino-bee-developer[/url]
Can I ask what you need to know? My interpretation of the GHI 4.3 implementation is that pretty much everything is easy to do on any board, obsolete or not. Exploring the GHI Pins assembly should reveal most of the things you need - I’d be very interested to know what else might be needed
@ jbermudez - all of the nermf manual pdf examples should work. Please take a look and let us know what else you need.
Welcome to the community.
Thank you very much for the fast answer.
I am trying to control a driver for an stepping motor (The driver is the A4988). It is addresed just by using a set of digital outputs for the config and a pulse signal (generated for example with a timer) for the step.
