Looks like you need to remove and re-add references for the GHIElectronics.Gadgeteer.FEZCerbot project and then rebuild it.
Ah. Makes sense. Iāll have to pull down the source and build it locallyā¦and done!
That got me to debugging, but Iām not seeing any Cerbot-specific functionality hanging off the Mainboard instance. Will have to keep digging, I suppose. Looks like the mainboard driver classes are pretty Spartan.
Guessing here, but my next step should probably be to go find the FEZCerbot mainboard code from GHIās repo and port that to this project?
Of course, given that I have an older hardware rev., that code may need to be modified anyway.
I have the same problems with my CerBot.
I tried all the tips mentioned here.
Is there anyone having a working solution?
btw. the deamonTutorials install into a different directory. (One Space missing)
@ GHI:
It would be very kind to insert the discontinued boards into the discontinued modules library!
@ mflume - everything is coming back in the next sdk coming in about couple weeks
After some hours I got it running with all features.
If someone canāt wait til next release, ask meā¦
@ All - For all those that want the Cerbot bring to life https://www.ghielectronics.com/community/codeshare/entry/1018
